Results 1 to 3 of 3
Thread: Slapping/knocking in engine on cold start
    Kitchener, Ontario, Canad
    2 x Euro-spec E36 M3s
    So, I own a ‘94 3.0L 5-speed Euro spec car that came from Japan. It has 130K km or 81K miles.
    On a very cold start, like 8+ hours, I get a fairly noticeable knock, that turns into a deeper banging, if revved up. If I let it idle for around 2 minutes, it’s very slightly rough, until I get a distinct change, and the issue disappears completely.
    i put a new timing chain tensioner in, thinking it was bleeding down, but the issue has not changed.
    Could something in the VANOS be moving around, until it gets enough oil flow? It’s got a good oil in it, and less than 3K miles on the oil.
    TIA.
    Cheap. Fast. Reliable. Choose 2.
    Avus Blue '94 M3 Euro-spec
    Arctic Silver '94 M3 Euro-spec - sold
    Estoril Blue '97 M3 Euro-spec
    The Netherlands
    DE-spec E36 328i/M3 cab
    As always, hook it up to BMW diagnostics software and read out all error memories. This might give you a good indication.
    No need for playing guessing games.
    1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
    IG:
    Thanks for the input. I don’t have a good example of it up and running. I’ll get that going, eventually. I asked here, to see if anyone with a similar car had a similar problem. I’ll figure it out.
  1. Odd e36 problem with the engine / MAF / Cold start
    By Denjeesi in forum 1991 - 1999 (E36)
    Last Post: 11-17-2018, 08:16 AM
  2. 06 Z4 3.0i knocking when engine is cold? No warning lights.
    By Johnny87 in forum Engine Conversions
    Last Post: 03-24-2018, 09:39 AM
  3. Brief knocking noise on a cold start (M54 engine)
    By adam1979 in forum 1996 - 2003 (E39)
    Last Post: 04-15-2013, 04:23 AM
  4. engine knock on cold start
    By Cavi in forum 1983 - 1991 (E30)
    Last Post: 09-26-2011, 09:32 PM
  5. Engine knock at cold start...normal?
    By dsuraci in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-19-2008, 11:29 PM
