Page 11 of 30 FirstFirst ... 23456789101112131415161718192021 ... LastLast
Results 251 to 275 of 747
Thread: Transmission case sleeves, ZF 4HP22/24 EH valve body questions
  1. #251
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    No, torque converter lock-up clutch is controlled by a dedicated solenoid to be applied only when cruising by removing pressure to the TCLUC - all explained in this document:
    https://www.meeknet.co.uk/E38/BMW_Tr...damental_1.pdf
    My BMW Repair YouTube Channel
  2. #252
    Oldham UK
    '00 330i Sprt '92 525i
    The TC is not going to be locked all the time. You could bump start the car if it was. It is a single plate clutch on the 4HP22 so probably works like this:
  3. #253
    May 2013
    Canada
    1990/02 BMW 735iA M30B35
    Yes.If that working with pressure regulator solenoid only than don't need any load springs between converter housing and clutch all work done through input shaft by pressure. Pressure between converter housing and clutch should be around 80-110psi than not engaged at low RPM 750 in position D or R. Pressure always in between converter housing and clutch should be more than between turbine and impeller.
  4. #254
    May 2013
    Canada
    The torque converter clutch locks the turbine to the converter housing... This can only be achieved at higher engine speeds, the torque converter clutch must be disengaged at low engine speeds to prevent stalling and slipping but if pressure regulator solenoid not adjusting pressure according to low engine speed 750RPM than it makes a bit more oil pressure or less oil pressure between turbine and impeller but when less oil pressure between turbine and converter housing at this point clutch begins to slip lightly one's you put gear selector to position D or R. This adjustment makes TCU. At higher speed TCU pick up signal from TD signal is crank shaft sensor and pick up signal from transmission output shaft sensor than TCU andjust pressure for pressure regulator solenoid and shift solenoid to release pressure between converter housing and clutch through input shaft and pushing clutch towards to impeller make unlock and whe pushing from impeller to turbine make lock.
  5. #255
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The TCU does not pick up the speed signal from the differential. Input from TD (engine speed) of the engine, output sensor in trans on the 4hp22
    Here explained on page 12 https://www.meeknet.co.uk/E38/BMW_Tr...damental_1.pdf
    Turbine Speed Sensor
    The Turbine Speed Sensor is used to provide input (turbine) shaft speed information to the TCM (EGS). The input shaft speed signal is used in conjunction with the output shaft speed signal to determine gear range and slip time information for processing in the TCM. Not all BMW transmissions use a turbine speed sensor. Some TCM’s use the TD (engine speed) signal to determine input shaft speed. All transmissions with the exception of the A5S325Z
    use an inductive type sensor which generates an AC analog signal. The A5S325Z currently uses a Hall Effect Turbine Speed Sensor which will send a digital square wave signal to the TCM.
    4HP22/24 (EH), A4S310/270R: These transmissions do not use a Turbine Speed Sensor. The TD signal is used to determine input shaft speed. The TD signal is an output signal of the DME control unit.
    A5S310Z, A5S325Z, A5S440Z, A5S560Z, A5S360/390R: These transmission use a turbine speed sensor. The TD signal is also used with the turbine speed signal to allow the TCM to monitor Torque Converter Clutch operation. The TCM can control torque converter clutch slippage and also monitor for faults.
    Output Shaft Speed Sensor
    The Output Shaft Speed Sensor is used to provide output shaft speed information to the TCM. The output shaft speed signal is used in conjunction with the turbine speed signal to provide the TCM with information on gear ranges and slip times. All BMW electronic transmissions have an output shaft speed sensor. The output shaft speed sensor is an inductive type which will generate an AC analog signal to the TCM. The frequency and amplitude of the signal will increase as output shaft speed increases. The exact location of the output shaft speed sensor varies by transmission model
  6. #256
    May 2013
    Canada
    I thought signal go to cluster from differential vs sensor than from cluster go to the TCU. The TCU must look at road speed and making shift after 90km/h. Ok I see now the output shaft sensor pick up signal from when faster output shaft spins at higher speed than TCU read that signal and make a gear shift same as lower gears and DME TD pick up signal from crankshaft sensor that is like input shaft than send signal to TCU and in higher gear lock up solenoid makes pressure adjustment to lock last gear which is must be 10 PSI at T/C release plug. IF is pressure different at low gears around 80 PSI that means something is wrong and clutch not engaged.
  7. #257
    May 2013
    Canada
    This is new product hook up through USB port have you ever try that For BMW Diagnosis Dis Sss Progman GT1 Ops Ncs Expert Encode Ediabas Inpa Fits. Thanks !
  8. #258
    May 2013
    Canada
    Item Description
    With us you get the latest version 2016 of the Ediabas Inpa diagnostic interface with new integrated DigiConX technology!
    The interface is compatible with the Ediabas / Inpa, NCS Expert programs
    DIS, GT1, WinKFP, SSS and Progman! (not
    iincluded in delivery)
    By combining it with the latest technology, it is now possible to have a stable USB connection
    to manufacture your BMW vehicle.
    And now without the well-known synchronization or timing problems, which are mostly
    caused by the USB converter.
    Activate the TV function, let your sunroof close automatically when it rains, for example open the driver's window in hot weather by tapping your remote control twice
    halfway or activate the optical and acoustic acknowledgment (blinker and horn sound) when unlocking and locking.
    With this interface and the appropriate software (not included) you have access to almost all functions that are possible in your vehicle.
    Read errors, delete errors, reset inspection intervals / service, reset airbags, activate auxiliary heating, activate US parking lights, fold in mirrors at the push of a button,
    Activate indicator acknowledgment when locking and unlocking the vehicle and much more ...
    There are countless more settings
    that can be made ....
    If you own a BMW , not all of the options that are possible will certainly be activated in your vehicle.
    Some things are withheld from US vehicles, for example, or were not selected when the vehicle was purchased.
    If you want to activate such options afterwards, you pay at
    BMW dealer approx. Some things will not be activated for you by the dealer at all.
    With this diagnostic device, there is no need to drive to the workshop!
    Please note that the coding of the vehicles requires appropriate specialist knowledge in the area and therefore cannot be carried out by everyone!
    You can find a lot of information about the corresponding codings in many forums or directly via google ;-)
    Properties / performance features:
    - Short-circuit proof
    - In-depth diagnosis possible
    - Vehicle coding possible
    - robust and suitable for workshops
    - Powerful and best quality
    - small and compact thanks to high-tech digital technology
    - Complete electronics in SMD and industrially manufactured
    Compatible operating systems:
    (each 32 & 64 bit!)
    - Windows 2000,
    - Windows XP,
    - Windows 7
    Technical specifications:
    - OBD-2 connector - cable length: approx. 1.2m
    - High Speed ​​USB 2.0 (but also USB 1.1 compatible)
    - Communication protocols: ISO9141-2, KWP2000 and others
    - Power supply: 12V through vehicle diagnosis socket (OBD)
    Supported vehicles:
    The following BMW models are supported:
    (For the models from 2006 only the pre-facelift models)
    3 series - E36 E46 E46 / 2 E90 E91
    5 series - E34 E39 E60 E61
    6 series - E63 E64
    7 series - E32 E38 E65
    8 series - E31
    X series - E83 E53 E70
    Z3 - E36 / 7 E36 / 8
    Z4 - E85 E86
    Z8 - E52
    Supported control units:
    Engine ABS airbag radio steering wheel clutch
    Power steering, air conditioning, sound system
    Immobilizer dash panel insert
    Level control system engine electronics II
    Engine electronics III automatic transmission
    Central locking Central comfort system
    and many other control units ...
    Scope of delivery:
    - Ediabas / Inpa compatible USB diagnostic interface
    - An easy-to-understand guide to installation
    of the Ediabas / INPA - NCS EXPERT package,
    as well as detailed coding instructions by email
    Supported Operating Systems:Windows XP (32-64 bit)
    Windows Vista (32 bit)
    Windows 7 (32/64 bit)
    vmWare Images
    With Windows 7 and Windows Vista you have to carry out the installation in XP compatibility mode!
    * Minimal processor clock
    (You need at least 300 Mhz)
    * Minimum RAM
    (You need at least 128 MB RAM)
    * Minimum hard drive space
    (You need min. 2 GB free hard disk space)
    * Compatible with Allen USB interfaces
    (USB 1.1, 2.0 or 3.0)
    The installation:
    Installation is extremely simple:
    1. The FTDI driver must be installed before use.
    2. Then in the control panel
    the "Device Manager" menu can be opened.
    3. Under the item "Connections" the
    new "USB Serial Port" must be selected.
    4. On "Extended" the COM port has to be opened
    Port can be placed between one and eight.
    5. The waiting time for the BM settings
    must be one millisecond.
    6. The obd.ini file must now be in
    moved the folder C: Windows
    and restart the computer.
    7. The driver installation is now complete.
    For BMW vehicles from 1996 to approx. 2007
  9. #259
    Oldham UK
    Quote Originally Posted by Annddrriy View Post
    Your car's system is ADS not OBD. It will have the round connector under the bonnet - not the OBD one. The advert says the cable will work with the E32 but production did not fall within the specified dates. So maybe confirm with the seller if this device will actually work with your car?
    It is possible to have an interface with both ADS and OBD but you will need the apppropriate adapter, switching and software to run both.
  10. #260
    May 2013
    Canada
    Yes. When I try to compatibility check with car I can not find the year and model for a car but when I check fitment its fit what I'm looking for. Did you try GT1 working good ?
  11. #261
    Jan 2005
    Japan
    A friend bought one "replica" made in China, it never worked, he scrapped it, some hundred $ wasted money
  12. #262
    May 2013
    Canada
    Do you know if GT1 has oscilloscope built in I would like to check ignition wires for misfire and scan ABS module and check for any code from instruments cluster. Cluster speed gauge keep moving without any reason. One guy changed capacitors in cluster and not fix the problem maybe problem somewhere else. I think I have to buy GT1 from another brand but not replica it might work.
  13. #263
    Jan 2005
    Japan
    I do not know how the GT1 works, as my friend never got it working. No need to spent thousands of $, ignition wires are easy to test with a multimeter, more here https://axleaddict.com/auto-repair/C...ple-strategies
    I have a inline spark tester for abt. $10, works fine. easy to use: Easily determine which cylinder is causing issues with this spark plug test light; Simply connect the spark detector spark plug tool between the spark plug and the plug wire then start the engine; If sparks are being sent, the in line spark tester will mirror the spark by lighting up; If checking a no start condition, have a friend crank the engine so you can watch for indications of a spark
    Light indication: Spark plug light spark checker indicates inconsistencies and sparks in a way that keeps you safe from electric currents; Intense bright white light indicates a healthy spark while jumping and dim color indicates a weak coil or plug; Remove the guesswork by using this spark plug tester and coil pack tester
    ABS can also be tested or sent to a repair shop for rebuild, clusters are cheap or can be repaired by https://www.programainc.com/
    advanced_hints_and_tips_bmw_abs_problems http://www.bba-reman.com/gb/content/...w_abs_problems
    ABS sensor testing http://www.bimmerboard.com/forums/posts/888672
    ABS/ASC blink test code - test it http://www.bimmerboard.com/forums/posts/819382
    ABS modules are also cheap available as used part, buy one and swap.
    Change the speed sensor on the diff and the wires coming out, maybe just a damaged wire or oxidized which cause the cluster problem. The Speed sensor is located at the back of the differential housing in an inaccessible location... follow the only wire.
    Failure syndromes: Erratic or no speedometer, erratic or no speed control, erratic wipers functioning.
    ECU repair example https://www.ecudoctors.com/pages/95-testing-service#
    A tester is not a magic tool, you have to inspect the items in question
  14. #264
    May 2013
    Canada
    When engine at normal operating temperature in automatic transmission ZF4HP22EH oil level should be on dipstick between two notches. Anybody know what oil level should be on dipstick in automatic transmission ZF4HP22EH when engine not running and cold ? Thanks in advance for your answer ?
  15. #265
    Jan 2005
    Japan
    when engine is not running for a long time, ATF will drop from the trans into the oil pan from all oil passages from the trans which is normally filled with engine running.
    You can see that even when the ATF is hot and you have removed the oil pan and the oil filter, it takes a very long time till it stops dripping out of the trans. So I "assume" when engine was not running for a looong time and you check the ATF with engine not running, the volume in the pan will be more = level at dipstick higher, even if the ATF is cold = total volume reduced, because all has dropped out of the system into the ATF pan.
    The instructions are to run the engine and the aircon, this will increase the idle speed and ensure that all oil passages in the transmission are filled with oil. Also one should shift thru all gears, pausing briefly in each gear
    Of course also the oil temperature makes a difference in ATF volume. For example on the GM transmission dipstick there are 3 balls for
    max at 80 DC
    min at 80 DC
    min at 40 degree Celsius
    and the difference between min and max is 0.3 liter.
    4HP22/24 with dipstick and filling from top thru dipstick pipe: 1988 E32 owners manual states on page 63: automatic transmission, checking oil level: the car must be standing on a level surface with the transmission at operating temperature 80 degree Celsius. Allow the engine to idle with the selector lever at P or N. Pull out the dipstick, wipe it with a non-fluffy cloth and push it back to measure the oil level. It must be between the two notch marks.
    The quantity of oil represented by the space between the two marks on the dipstick is approx. 0.3 liter when the transmission is at operating temperature. If necessary, add fresh ATF at the oil level check pipe.
  16. #266
    May 2013
    Canada
    Yes all oil has dropped out of the system into the ATF pan than make oil level on dipstick higher than upper notch mark. Maybe 25mm higher.
  17. #267
    May 2013
    Canada
    Do you know what vacuum makes oil pump from the stator input shaft housing pump suction output plug ?
  18. #268
    Jan 2005
    Japan
    Not mentioned in the workshop manual. Check the 4HP22 repair manual from ZF, if there is something mentioned
  19. #269
    May 2013
    Canada
    Is Line Pressure port and "A" Clutch pressure port that is same pressure or different pressure ?
  20. #270
    Jan 2005
    Japan
    That changes depending on the requirements, if understand that correct, excerpt: Magnetic Valves Magnetic Valves (MV) are used to electronically control hydraulic fluid flow to the various shift elements within the transmission. Magnetic valves are located on the valvebody and replaceable as separate components. In ZF transmissions, MV valves are designated MV1, MV2, MV3 etc. The magnetic valves are controlled by the TCM. They are supplied power by an internal TCM relay and are ground controlled. The TCM switches one or more of the MV’s on or off in various combinations to achieve various shifts. Most transmission have 2 or 3 MV’s to control shifting. In addition to controlling shifts within the transmission, magnetic valves are also used for overlap shifting and pressure regulation on some transmission applications. For example MV4 and MV5 are used for overlap shifting in the A5S310Z. MV5 is used for pressure regulation on the 4HP22/24EH transmissions. When used for pressure regulation, the magnetic valves are pulse width modulated by the TCM. read more here https://www.meeknet.co.uk/E38/BMW_Tr...damental_1.pdf
  21. #271
    May 2013
    Canada
    Pressure at "A" Clutch in third gear probably get lower than in first forward gear. TCU solenoids positive power get input pin #1. TCU ground controlled output to solenoids. Do you know what readings should be at scope trace when checking transmission output shaft sensor ?
  22. #272
    Oldham UK
    The Tech Guide says the spec is 265 ohms between pins 8 and 27. But I believe it is more like 325 ohms at 20C. When the sensors go, the resistance is usually very high indeed and you cannot miss it. Voltage wise, the spec I have is 3.5V AC at about 20 mph. As that is AC volts, you may need to insert a blocking capacitor if your meter does not have one
  23. #273
    May 2013
    Canada
    The spec is 265 ohms between pins 8 and 27 doesn't do correct reading under load with multimeter you going to miss it right readings. I need scope to check that. When I get scope usually has build in all sensors specs.
  24. #274
    May 2013
    Canada
    When pressure goes to "A" Clutch also goes to torque convertor to make oil coupling between turbine and impeller this time pressure should be more in torque converter than in "A" clutch ? T/C release will get pressure around 120psi and "A" clutch will get pressure around 80psi. If "A" clutch and T/C release will get wrong reading on the oil pressure gauge that is something wrong with hydraulic system.
  25. #275
    May 2013
    Canada
    Quote Originally Posted by whiskychaser View Post
    If specs 3.5V AC at 20 mph. what is the frequency and amplitude for automatic transmission speed sensor ?
    What AC volts will be at 1 mph ?
  1. ZF 4HP22/24 + 5HP30 valve body overhaul in detail
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 11-27-2013, 09:13 AM
  2. 4HP22 automatic transmission valve body questions
    By Dash01 in forum 1988 - 1996 (E34)
    Last Post: 09-24-2009, 10:47 PM
  3. transmission ZF 4HP22/24 solenoid test
    Last Post: 09-23-2009, 07:38 AM
  4. Repair of ZF 4HP22/24 transmission - DIY info
    Last Post: 10-07-2007, 10:08 PM
