Looking for a temp spare rim for my 2015 528I to back up the (Run Flats). I know the main problem is the off sets so could I use a late 3series rim or stick with 5 series?
well its a combination of offsets and wheel width, nevertheless I can't help you too much if i don't know the wheel specs of the late 3series you mentioned, i would recommend to have a look at this resource i'm sure it will help you figuring out the right fit https://www.bmwstylerims.com/bmw-whe.../#BMW-Series-5 hope it helps
I think that the 3 series bolt circle is different than the 5 series.
