I've googled quite a bit and found LOTs of info on coupes and sedans about OEM sway bar upgrades...but not a lot on verts!!
My 02 325CIC has stock 23mm front and 18mm rear sways.
Junkyard scored a 330I 23.5mm front sway bar and a 330CIC 20mm rear sway bar...
Would this combo work better than the oem 24mm/20mm ZHP convertible combo???
Please chime in!
dc
"Better" is a relative term. Basic facts are the bigger the swaybar, the less body roll you get in a corner with minimal impact on ride quality. That said, a 24mm bar will reduce body roll more than a 23.5mm bar. Is it a difference you will notice? Probably not. Are the swaybars you junkyard scored bigger than the ones currently on the car? If yes, then it will corner flatter.
Sent from my SM-G970U using Tapatalk
