Results 1 to 3 of 3
Thread: Advice: New Owner 2011 740i F01
    Dec 2020
    Taos, NM
    E32 750il -and E90 F01
    Fellow Members:
    Recently purchased an '11 740i and loving it.
    My baby is still my E32 750iL but my bimmer disease has taken hold and I "needed" another fix.
    This N54 engine is certainly fun but I thought I'd ask the community advice on what to look out for and anything I can do preemptively to avoid any problems.
    Any advice, questions or comments are welcome and encouraged.
    Jan 2016
    Ca
    2001 525it
    5 or 7.5k oil changes, regular maintained check spark plug change intervals. Service the trans
    Dec 2020
    Taos, NM
    Thank you Jbird
    80k miles 2011 740i 10/2010 prod. N54B30 240kw
    I've been doing the typical research and this is what I've gathered along with some questions:
    Please correct, comment, reply. Its much appreciated.
    - The increased interval of oil changes to prolong turbo life
    - HPFP tendency to fail prematurely (is this due at 80k?) (Are the performance replacements worth using?)
    - Valve Cover and Gaskets crack fail often
    - Fuel injectors will fail
    - OFHG leaks (possible serpentine belt damage)
    - Carbon build up on intake valves
    - Electric water pump and thermostat (~60k?)
    - Wastegate rattle (can the wastegate be upgraded/fixed or just upgrade to new turbos?)
    - oil pan gasket
    Ive noticed the engine seems to run hot. Oil temp stays at okay temp but engine and bay seem to stay hot for a long while after turned off.
    Are the oil cooler valves a safe option to run cooler temps? any other ideas to keep temp down without risking oil not making it to turbos?
    Where in the h is the coolant drain? Lowest most hose? Looks like PO filled it with the pink stuff. I need to get that crap out.
    Because most of the info out there on the N54 is coming from the E9X's which is slightly different, I have noticed:
    I only have a single diverter valve on my charge pipe although even realoem shows two diverter valves as do most videos i come across.
    I have hot climate option so i do have an oil cooler but the oil filter housing looks different than other N54's.
    Where can i find a good amount of info on this model?
  1. New Owner 2011 335XI,Rim Help
    By MCinek in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 03-05-2011, 11:40 AM
  2. New Owner 2011 335XI,Rim Help
    By MCinek in forum Tire & Wheel Forum sponsored by The Tire Rack
  3. New owner 2000 740i!!!
    By bjb1323 in forum 1995 - 2001 (E38)
    Last Post: 09-26-2010, 06:03 AM
  4. New Owner - 2001 740i Sport
    By BBiggs in forum 1995 - 2001 (E38)
    Last Post: 05-11-2008, 11:40 PM
  5. New Owner 94 740i
    By NotUrSistersMx5 in forum 1988 - 1994 (E32)
    Last Post: 11-18-2007, 06:42 PM
