Results 1 to 4 of 4
Thread: 550i E60 N62 TU 4.8 Engine rattle at idle only at full operating temperature
    Apr 2018
    MIAMI
    BMW 550i e60
    Hello to everybody, I was trying to find the source of a noise coming from the engine of my 550i E60 the noise appears to be coming from the top part of the engine it does it only when its idling and only when it reach full operating temperature.
    There are no noises at cold stars and the noise automatically stops when you step a little bit on the gas.
    So far I did the following things:
    Scan with INPA and ISTA (No codes where found)
    Check the Valvetronic motors and reset the positions with ISTA
    Check eccentric shaft teeth and were good with no wear
    Video From the noise 0:18s (YouTube)
    https://youtu.be/Q2t5WLGIoAQ
    Apr 2018
    MIAMI
    BMW 550i e60
    Could it be the intake manifold valves?
    Enviado desde mi SM-A205G mediante Tapatalk
    Feb 2015
    Nevada City, CA
    E60 550i 6MT
    Just curious if you ever found the solution. My 06 550i 6MT just started making this exact noise
    Apr 2018
    MIAMI
    BMW 550i e60
    Yes it was the belt tensioner that was bad I replaced it and the knock was gone, check your water pump also to see if it has play on the shaft.
    Enviado desde mi SM-A525M mediante Tapatalk
  1. 2006 E83 M54 Engine Rattle at Idle
    By gdking32 in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 11-22-2020, 05:22 PM
  2. Terrible engine rattle at idle
    By Mikec205 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 04-08-2020, 09:11 AM
  3. Replies: 1
    Last Post: 07-20-2010, 06:31 PM
  4. yet another problem, engine rattle at idle
    By matthewo in forum 1999 - 2006 (E46)
    Last Post: 12-31-2007, 02:25 AM
  5. Engine rattle @ 1400rpm?
    By bimmer95 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-25-2001, 04:23 PM
