Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 4 of 4
Thread: lost for sizing
    Jun 2019
    Canada
    '88 735i
    lost for sizing
    Hello everyone,
    So i recently purchased a '88 735i has the stock rims and tires on it... some 15inch tiny wheels i think style 2s? anyways only reason im not putting new tires on those 15inch tires is because I can't get any for a reasonable amount of money where I live, and I have a on cost dealer connection.
    So I recently bought some 16inch style 5s from a E38, looks like the guy was running 235/60/16 in the rear and 225/60/16 in the front. Fit mint looks great but not stock, and im looking for stock finish ride hight.
    So my question is, in an attempt to prevent anything rubbing and to get some modern rubber on this E32, what tire size should i be running all round the car, same size as what i just got on the car? or should be going 225/60/16 at all four corners? or something different all together?
    new to the forums so if this question has been gone over id appreciate a link, thank you for your time
    Lincoln Park, NJ
    2018 M3 6MT, 2001 740iL
    According to tirerack an '88 735i on 16" wheels would get 225/55-16. What you have has 11 mm larger overall radius/ride height. Not -that- far off. No idea about offset differences on the wheels. Very likely there is room to go wider if that is your thing.
    Jun 2019
    Canada
    '88 735i
    I need to take a long look at the front wheel figment. might go with that 55 hight. i really dont want to hear any scraping of rubbing from the inner wheel well or fender lip. Either way thank you!
    May 2022
    Phoenix,AZ,USA
    1986 535i, 1997 LX450
    According to my recent research (for my 1986 e28 535i - should be quite similar, no?)
    BBS Basketweave Style 5 from M5 e28 / 7.5J x 16 et20.
    This wheel should be an ideal stock replacement for your 735i, and a very versatile easy size to fit a variety of tires - just choose the overall diameter & section width relative to whatever OEM was.
    Double check your actual offset (ISxx) in mm usually cast into the back of the spokes.
  1. Lost a nut.... Need Size
    By dk500 in forum 1996 - 2003 (E39)
    Last Post: 09-10-2015, 08:01 PM
  2. Tire Size for wheels...I'm lost.
    By M3People in forum 1996 - 2003 (E39)
    Last Post: 01-25-2010, 11:08 AM
  3. Survey: What size tires are on your 17" rims?
    By bmwmsport in forum 1991 - 1999 (E36)
    Last Post: 06-06-2005, 10:04 PM
  4. Lost my wheel lock key.need size socket to remove lock
    By BzAlwayzLit in forum 1991 - 1999 (E36)
    Last Post: 02-08-2003, 05:37 PM
  5. What size front wheels came on 97+ M3's?
    By bmwmsport in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2001, 08:58 PM
