Results 1 to 9 of 9
Thread: Noise from Diff area
    Dec 2020
    Las Vegas
    1995 BMW E36 318ti
    Hi friends,
    I found this noise from diff area. And I found that when I jack up the car and spin one wheel by hand the other wheel doesn't spin. But, both spins when I shift the gear. Can anyone say what is wrong with.
    https://www.youtube.com/watch?v=Izr5JDCKI40
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E36 forum
    Oct 2005
    Canberra, Australia
    93' Turbo 325i Coupe
    Potentially nothing wrong with it. Had a listen to the video, can't hear much tbh. The reason one wheel spins and not the other is because it's an open diff, not an LSD. (dont do it) but I bet if you grabbed one of the wheels while it's spinning, it would stop and the other would keep spinning. The slight noise you hear could just be that metal cap on the front of the diff rubbing as it spins.
    Really hard to say what/if any of the issues are from that description and video unfortunately, so if you're really concerned take it to a diff specialist to have a listen.
    Dec 2020
    Las Vegas
    1995 BMW E36 318ti
    Hi! @dominator293 thanks for the reply. It is 1995 318ti with Sport suspension over 300k miles and most of the parts are originals. When I run the VIN it shows that it has a LSD. I think that the LSD is gone as described in the following video. As you stated the noise may be from the metal cap. I thought it is from bearings. I am going to remove the diff cover and check inside.
    https://www.youtube.com/watch?v=q_ra...l=Garageaholic
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Quote Originally Posted by AKBO View Post
    Hi friends,
    You have an Open Diff, this means that in N, you can turn a tire and the opposite tire does not turn because the driveshaft turns instead. If you put the gear selector into P, or 1st, then the opposite side tire will turn opposite the direction of the tire that you are turning. This is normal and customary, so you need to give more information as it regards to the noise.
    Oct 2005
    Canberra, Australia
    Also the LSD diffs have an 'S' written on the little tag on the bag of the diff, or a big S painted on top of the diff. If you don't see one, likely not an LSD.
    Dec 2020
    Las Vegas
    1995 BMW E36 318ti
    Quote Originally Posted by JDStrickland View Post
    @JDStrickland Thanks for the information. What kind of information would you need regarding the noise?
    Quote Originally Posted by dominator293 View Post
    Thanks dominator293 I'll check it.
    Jul 2010
    Murrieta, CA
    I see that you say that you have a 318 that came with an LSD, this sounds odd. I would not expect any 318 to have a factory LSD, but I suppose it's possible. Having said that, the LSD can be the cause of any noise you have.
    Do you have any audio of the noise you are chasing?
    Wheel bearings are far more likely than the diff to make noise. The diff is pretty much filled with oil, it has enough oil in it to bathe everything with oil as it spins. The wheel bearings run dry, they only have the lubrication that they came with from the manufacturer, so they will have a tendency to run dry from time to time, this is especially true if you take your car swimming (drive through deep water that is axle deep). Tires can make noises too.
    Dec 2020
    Las Vegas
    1995 BMW E36 318ti
    @JDStrickland Thanks for the reply. I don't have an audio file except the YouTube video with above link. When I listen to the noise moving here and there, I here it loudly in the centre area.
    Here is where I found the details about the Diff. May be I am wrong.
    http://bmwfans.info/parts-catalog/E3...ar_axle_drive/
    Here is the YouTube link again if needed.
  1. grinding noise from diff. area
    By contor in forum 1991 - 1999 (E36)
    Last Post: 12-30-2010, 03:21 PM
  2. diff/bearing noise? - good Seattle area mechanic?
    By supark in forum 1991 - 1999 (E36)
    Last Post: 06-25-2005, 05:35 PM
  3. Thumping Noise in Diff
    By GTR-M3/4 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-16-2004, 03:33 PM
  4. Strange noise from radiator area when Lights are on
    By Blazin95Red325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-28-2003, 03:53 PM
  5. screachy noise from brake area's
    By slvrm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-16-2002, 12:54 AM
