I am aware that the "big 3" is rear subframe supports, rod bearings, and VANOS. My question is about the VANOS portion.
Assuming the rebuild of the VANOS using the Beisan oil pump, is the exhaust cam oil pump drive considered a required replacement as well?
Are you talking about the hub? if so, I would HIGHLY recommend upgraded to one that is stronger.
