Results 1 to 25 of 44
Thread: Turbo LS e39 Touring
    Norristown PA
    mostly bmw
    I finally found an e39 touring worthy for the build.
    I purchase a 2010 Camaro SS a few months ago and have this ready to go in:
    I'll be getting a WiringSpecialties harness. Likely going with a Haltech ECU but hasn't been finalized just yet. As you can see, I have the SIKKY pan and engine arms on it. Plan to go with a single GT42 turbo and a little boost. Phase two is build a truck iron block and run e85. Hopefully I build the iron block before I turn the boost up too much on the Camaro aluminum block!
    I don't think I have the skills yet, but I'd like to figure out how to mount a Ford 8.8 in the rear. Anyone here have or know someone who has said skills?
    95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
    Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
    Houston, TX
    1997 M3 Sedan
    Quote Originally Posted by bubela View Post
    I think the GT42 is going to be too small for you. I ran one on a 383 sbc and the turbine side was definitely too small. I measured ~3x boost pressure between the engine and the turbo on the dyno. Spool up was instant, though. I think the GT42 turbine is better sized for a 4.8 or 5.3. I think the 6.2 is going to need a GT47 turbine or similar.
    Sent from my iPhone using Tapatalk Pro
    Norristown PA
    mostly bmw
    Thank you for the feedback. I don't want a laggy turbo, hence why I think I'm going to stay with it for now. If it dies up top, I can always step up. By then there will be a new, greater turbo with more efficiency!
    A dozen years ago on my first turbo build ever, I went with a T4 instead of T3 and spool suffered. I've since erred on the side of caution and stayed "relatively" small. My m3 is running a PT6466 and maxing out at 870whp. I wouldn't change a thing there. My 996 is running two 6266s and they're a bit laggy. Can definitely make a decent amount more power than it's currently making.
    Houston, TX
    1997 M3 Sedan
    Well, you definitely won’t be laggy with the GT42. I shut off the Dynapack I was running on because of over-torque. After that, I made another hot side for a T6 turbine inlet, then switched from a T4 0.96 a/r to a T6 1.15 a/r housing, which seemed to help but I never dyno’ed it again. My C5 RS6 with stock K04’s reminds me a lot of the old Malibu with the GT42. Spools instantly and pulls like a freight train but all done around 5.5-6k rpm. If that’s what you’re looking for then it should be fine.
    Norristown PA
    mostly bmw
    Thank you for that feedback! You've described what I'm looking for, yes.
    I've decided to give the rear subframe an attempt on my own and hope for the best. I've never tackled a serious aluminum project before. First step, cut out the stuff that's in the way!
    See what a C grade hacker can make out of this. Picked up an Explorer differential at a local wrecking yard for cheap.
    Norristown PA
    mostly bmw
    Pulled the engine and detailed the engine bay a little today.
    Norristown PA
    mostly bmw
    Actually went in really easy with the SIKKY kit. Only thing I should have done prior was remove the sway bar. Sway bar hits the bell housing.
    Washington
    BMW 525i
    What is the space like on the Sikky kit to fit a down pipe? You have any shots of spacing around the mounts?
    Norristown PA
    mostly bmw
    It's looking pretty good. I only have the one picture that doesn't even show the mount in the picture but gives an idea of the space. I know I can fit a 4" down pipe between the header/AC compressor/AC lines. I'm going to see if I can jam a 5" pipe down there.
    Norristown PA
    mostly bmw
    After some consideration, looks like I'm now leaning towards the Garrett GT4508R 108mm (80mm) w/ Compact 42, DIVIDED 1.01 AR T4. Leaves room for growth for when I have a built engine but should also spool early enough for my liking.
    Norristown PA
    mostly bmw
    First exhaust manifold I ever made! Pretty stoked.
    Norristown PA
    mostly bmw
    I'm trying to find a T4 flange but instead of having the inlets straight up, I need to have divided T in opposite directions. Kinda like the one pictured, but actually divided and also of higher quality. Machined would be perfect. I need a very tight 90 degree entrance from opposite directions. I’ll mount one manifold almost directly onto the T4 flange and then the crossover pipe would come in the other side. Otherwise, in order to use this sweet Street Carr Fabrication T4 flange I got, I’d need a number of really tight radius turns.
    May 2019
    Detroit , Michigan
    2002 525i Touring
    This is wonderful and similar to my end goal.
    Are you going to integrate cruise control and AC in an oem like manner ?
    Joey
    2002 525i Touring M5T Project
    2002 Subaru Wrx Sti Touring Project
    2013 VW Touareg TDI EPA Nightmare
    Build log
    https://www.bimmerforums.com/forum/s...M5T-Conversion
    Norristown PA
    mostly bmw
    I'll have AC but the cruise control is not on the list. I rarely drive far. However.. maybe one day if I get bored?
    Jul 2021
    Eastern Oregon
    E39.540i Touring
    I just joined the forum to follow your thread. I just picked up a 99 540i and I have an LQ4 sitting around begging to get built and swapped in eventually.
    Norristown PA
    mostly bmw
    That's great! Welcome to the forum. I'm trying to help keep this place alive. Builds on facebook are impossible to follow. bf.c is searchable for(ever?)!
    Norristown PA
    mostly bmw
    Norristown PA
    mostly bmw
    My first ever stainless tig weld is in this picture. I have WAY too many hours in to these so far.. ugh.
    Norristown PA
    mostly bmw
    Just winging it.
    Washington
    BMW 525i
    Curious to see your down pipe fitment with the sikky mounts. With Josh’s mounts I went under the arm but it looks like the sikky is placed a little lower and you are going over the engine mount arm and under your header.
    Sent from my iPad using Tapatalk
    2002 BMW 525i - 6.6L LS Turbo Swap
    Follow me on Instagram at @LantzFab
    Link to LantzFab.com
    Link to my Facebook page
    Link to my build page
    Norristown PA
    mostly bmw
    Yup. I'm going high with the passenger header and directly under the header is a 4" down pipe. It clears the sikky engine arm and leaves room for the e39 BMW AC compressor in the stock location. I've bent the AC lines pretty good. Probably have to re do them, but looks like it all fits.
    Washington
    BMW 525i
    When you have time post some pictures of the routing. I’m curious to see how much clearance.
    Norristown PA
    mostly bmw
    Haven't worked on it much the past two weeks. Here's a shot of the 4" down pipe next to the starter/bell housing.
    Norristown PA
    mostly bmw
    Got the first batch of the Sikky e39 Shifters for the TR6060. It's Perfect! So tight.
    Dec 2018
    Murfreesboro, TN
    '99 528iT
    Very exciting stuff. I definitely agree on the facebook thing, that and too many people asking questions they could find with a quick google search.
  1. E39 touring LS swap project
    By RVAE34 in forum E39 Touring / Wagon
    Last Post: 11-12-2022, 07:40 PM
  2. Replies: 76
    Last Post: 11-24-2019, 09:42 AM
  3. Project MF42 Turbo, e39 Touring, Among Other Things.
    By MF DOOM in forum BMW Rides & Events
    Last Post: 09-07-2013, 08:25 PM
  4. E39 touring LS swap project
    By RVAE34 in forum 1996 - 2003 (E39)
    Last Post: 12-02-2012, 02:58 PM
  5. Anyone here with an LS powered E39 touring?
    By five&dime in forum 1996 - 2003 (E39)
    Last Post: 08-13-2011, 02:15 PM
