Over the course of time I've collected a variety of parts from my 2 - z3s that I merged and turned into a track car. Items are generally in good condition or I can provide more detail and pics for an item as needed. Given the length of this list Im not going to try and post pics. Assume flat rate shipping cost if itll fit into a small, medium or large USPS box. Large items like body panels and drivetrain components are ideally local pickup, or you arrange for pickup/shipping. For anything else I can estimate with USPS or UPS. Price is best reasonable offer if the item isnt listed with a price, and even then its a best offer situation Im not looking to make much but hate to through this stuff out. As long as the offer is reasonable and makes it worth my time to box and ship, I'll take it.
Exterior and Body
Wiper arms & assembly w/motor (no blades) - $20
Narrow body rear quarters silver - $75
Narrow body rear bumper silver - $75
Narrow body trunk lid silver - $75
New front bumper support brackets - $20/each
Front bumper impact shocks - $20/each
Windshield cowl
Aluminum front bumper support - $100
Interior Items
Dash venting tubes (all of them)
Dash vent covers (center, corners, sides)
Blue A-Pillar covers
Steering column covers
Drivers knee bolster (have 2 1 of them has 1 broken tab, the other both are broken)
Metal trim brackets for dash components (have 2 sets and will break them up if needed)
Boomerangs black pleather style - $50
Trunk trim panel (the one attached to the inside rear-most trunk wall)
E-brake assembly
Interior door latches (1 set black, 1 set chrome) no trim plates - $20/set
HVAC faceplate
Window switches
Door sills say Roadster - $50 for the set
Passenger Dash Airbag cover plate black
Turn signal stalk (wiring has been cut but the plug is present and can be soldered back together)
EWS key ring (I have 2 functional, one of which is new)
Wiper stalk
Cruise control stalk (2 one has connector, other wires only)
Z3M water temp gauge - $35
Z3M Gauge blank insert
Convertible top switch
Hazard switch
Onboard computer
Side-view mirror controls
AC/recirculation switch (2)
ASC button
Steering wheel slip ring - $50
Seatbelts (inner seat buckle isnt available)
Exhaust
Rear M mufflers (rear section only) - $100
S52 stock headers - $50
Engine / Misc Engine Bay Items
S52 MAF - $125
Oil separator
S52 SAP
S52 steering pump
S52 fuel rail
S52 intake manifold w/injectors
Front subframe 1.9L
Cruise control actuator
Washer tanks (2 one without a pump)
Drivetrain
Non-M driveshaft (1.9L)
Steering pump underdrive pulley (TMS Branded)
S52 clutch assembly/flywheel
Small case diff - $100
Brakes
S52 brake booster - $25
S52 master cylinder - $50
S52 ABS pump - $100
1.9L ABS pump - $100
Accessories/Misc
Autometer Phantom A/F gauge (wideband)
Autometer Phantom Volt meter
Autometer fuel pressure gauge
Autometer oil pressure gauge
Control modules (all of them)
Tail light panels (electrical side in trunk)
Hey, I'm interested in some of the interior center console parts.
-Metal trim brackets for dash components
-Z3M Gauge blank insert
Can you send me some pictures and price please!
Thanks!
Ves
Do you have S52 pistons and rods by any chance?
No pistons/rods. Sorry - only what's listed.
I can't post pics in the classifieds, can you send me an email? $60 for the items you mentioned. I'll need to know which dash brackets you need to make sure I have what you're looking for - will discuss via email to avoid a lengthy post of back/forth since I know there are a lot of the metal brackets behind the dash panels.
