Results 1 to 6 of 6
Thread: Help removing manual trans - stuck
    May 2021
    niles, il
    99 323ic
    Are there any tips to separating the transmission from the engine after removing all the bolts?
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Wiggle, pry gently, make sure you've got ALL the bolts out, and that you're pulling straight out. Mine seemed stuck, then, suddenly, it came out.
    Jul 2003
    Spring, TX
    E36 328is, E39 M5
    There are two studs that corrode over time.... best you can do is keep wriggling until they let loose.... if you can get a gap started, then a pry bar, gently. Clean those studs and corresponding holes before reinstalling will make it easier to get it back together.
    Lime Rock Park... the most fun you can have in a mile and a half.
    Apr 2015
    Tennessee
    1998 BMW 328i
    Make sure the weight is properly supported too and don't drop it on your buddy's chest... The manual only weighs about 90 lbs so it's not too bad, but still
    Sent from my SM-G975U using Tapatalk
    Dec 2013
    People's Republic of MD
    22 doors and 4 tops
    Ensure the starter is off of the bellhousing. It sticks. Wack is forward with a brass punch etc.
    Are you sure you removed all the bolts?????? They like to hide a small one on the bottom and a 10mm bolt on the blockplate side under the rear exhaust manifold.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    I just took mine out (again... sad story). Since it had been out recently, it almost fell out this time. I put the tranny jack just touching the tranny, so I could wiggle it, while I pryed gently with a roofing-nail crowbar (example: https://www.lowes.com/pd/Estwing-15-...B&gclsrc=aw.ds )
  1. Help! E36 318i trans removal - starter stuck
    By tholt29 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-23-2013, 12:03 AM
  2. Replies: 8
    Last Post: 11-16-2011, 04:14 PM
  3. removing 318is manual trans help.
    By mike1111 in forum 1991 - 1999 (E36)
    Last Post: 10-07-2010, 10:14 PM
  4. Need help reinstalling manual trans
    By lindhaw in forum 1991 - 1999 (E36)
    Last Post: 08-16-2009, 11:55 PM
  5. e36 manual trans stuck in neutral
    By pilot650 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-14-2009, 01:59 AM
