Results 1 to 5 of 5
Thread: 2005 X3 2.5L what power steering fluid needed?
    Sep 2017
    bethesda, MD USA
    2005 X3
    I want to top off the power steering reservoir in my 2005 X3 (2.5L manual transmission). The reservoir cap says "ATF Only" and the fluid inside does look reddish. But everywhere I am reading that this model requires CHF-11S power steering fluid and that one is greenish. I am hesitant to mix the reddish fluid with this greenish stuff. Do I need to get some special ATF fluid to top off? Any recommended brands? Thanks in advance for advice.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to X3 forum from X general forum
    Apr 2014
    Renton, WA
    03 540i, 04 X3, 00 328i
    I think you won't go wrong if you use Dexron III or Dex/Merc ATF fluid.
    CHF-11S is/was required in some models, where also some other hydraulic components in addition to the steering rack were run by the same hydraulic system. If the cap says "ATF only" that's not the case for you. The color also tells Dexron type ATF is in your system right now.
    Sep 2017
    bethesda, MD USA
    2005 X3
    thank you all for reply. my mistake--- i will move to X3 subforum as advised by moderator.
    May 2012
    FL
    E83, E21
    As the reservoir has an integral filter, replace the entire thing. If you have any PS moisture on top of the reservoir (around the vent hole in the cap), you have a filter that has outlived its life expectancy. IF yours takes ATF, Dex 6 is the latest and greatest. You don't want to mix ATF and CHF; don't go by what's on the cap, as caps can be changed in the 16 years the car has been in existence. Dab a white cloth into the reservoir to get an accurate indication of its color rather than by looking into the reservoir. Smell it; CHF and ATF smell quite different. Mine takes CHF, but it is an LCI model with a completely different drivetrain.
    E21 build
    BMW CCA 584213
    I buy socks from Amazon.
  1. Power Steering fluid - ATF/CHF 11S? 2005 325i
    By BamaBMWgirl in forum 1999 - 2006 (E46)
    Last Post: 08-06-2018, 08:46 AM
  2. Help on Chaning Power Steering Fluid
    By Buddha in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-28-2002, 01:23 PM
  3. Symptoms of low power steering fluid???
    By seoulman in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2002, 01:02 AM
  4. Replies: 5
    Last Post: 03-13-2002, 01:25 PM
  5. Power steering fluid leak...HELP
    By BimmerXTC in forum 1991 - 1999 (E36)
    Last Post: 04-18-2001, 10:04 PM
