I have a 2018 x3 m40i. Do the 343m rims fit? They are 19s with 8.5 and 9.5 width. I like thr 19s for comfort, but want wider than favored 19s on it. These are already blacked out and are wider so would look good.
If you went to reloem entered the last seven of the vin go to section 36 you will see what size rims were available for this car. Also factory rims fit perfectly over the hub, ther hub centric rims, aftermarket rims most likely are not which means you need a centering ring so the wheel centers on the hub. The centering ring centers the wheel the lug bolts just hold the wheel on, they don’t center the wheel and because of this the car may feel like the wheels could be out of balance a bit , the best wheels are factory wheels because the fit perfectly over the hub
