Hello everyone, I am Daniel from Argentina, I have in my workshop a 2011 R60 mini countryman with a problem in the instrument lights. RPM works on the instrument behind the wheel and there is information on the display, there is no lighting, no wink lights work and there is no wink noise. there is no speed or fuel level on the central dashboard. radio display if it works with lighting.
There are no error codes when connecting the diagnostic tool, there are no blown fuses, the frm was replaced and it remains the same, the instrument was replaced behind the steering wheel and it remains the same, it looked for traces of water in the frm and juction box connectors and nothing.
I don't know what else to check, please help. I clarify that all the rest of the car works perfect, interior and exterior lights
Check for faults in the frm module ( footwell module)
hello jclausen, thanks for answering, I have a spare frm in my workshop, I tried it and it makes the same failure, what catches my attention is that there is no dtc in any module, but when I disconnect the battery and after 10 min I go back to connect the frm shows many dtc
A8AD ........ current
A8AC ........ current
A8AA, A8A8, A8C2, A8BA, A8B7, A8B3, A8A9, A8AB those history
but I erase dtc and they disappear, I put ignition repeatedly and they do not appear again, even the current dtc.
perform data flow in another mini the same, and they are the same.
I don't know what else to check.
