Originally Posted by
FlylowTX
2009 750li, 99k, pristine condition.
Went out one morning to go somewhere, and had no video display (so no radio or I-drive), no Heads Up, no rear entertainment, and no rear air suspension.
Everything else works normally, ie dashboard, a/c, windows, locks, engine, etc.
Took the car to Precision Imports in Frisco based on recommendation from another BMW owner. After three weeks, they are giving up. They said there is no communication between the modules. I asked if they use ISTA-P, and he said they did not, they used another "all-brand" generic diagnosis system (that apparently is very expensive). In their defense, they are not charging me (though they did install a new rear air suspension pump that I paid for, but it didn't change anything).
I called a BMW-only indy not too far, and they want $125 just to hook it up to ISTA-P and read the codes. They told me they had a 5-series with a similar issue, and they quoted him 12 hours labor to remove the interior and each individual module until they found the culprit. This sounds like a shotgun approach if there ever was one.
With my limited knowledge, this sounds like a Canbus network error. Is there a central communications module that everything goes through?
So, can anybody shed any light on what may be going on?
Is there a better way to diagnose the modules other than removing them all on-by-one?
Is it worth taking it to the stealer (somewhere I never go unless I have no choice).
I appreciate your time and thoughts on this matter!
