Results 1 to 7 of 7
Thread: Rear Tranny Mounts Damage
    Apr 2021
    Ft Myers FL
    1983 633csi
    So I have removed the engine and manual tranny all in one shot, out of my 1983 633csi and in doing so I have damaged the shifter holder mounting holes. Can I remove the bolts that hold these mounting brackets on the tranny and therefore make it easier for someone to fill and reweld the aluminum holes? also, do I need to re-torque the bolts when I put the mounting brackets back on? If so what would that torque # be? Or can I buy new ones?
    Sorry for the upside down pic's they are not that way on my computer, don't know what happened.
    Nov 2005
    Brookfield,CT
    '92 325IC '88 635
    Quote Originally Posted by SHARKNOVA View Post
    If you are talking about the pieces that are bolted on to the two towers, they are separate and replaceable ("supporting brackets" ) according to Realoem.com
    '88 635, '92 325IC
    West Nyack, New York
    86 635csi 98 740i 96 MB
    Jody,
    I just found them on Realoem also---
    Here is the page #21
    https://www.realoem.com/bmw/enUS/sho...diagId=23_0086
    Jan 2016
    Ca
    2001 525it
    If the mounts are that worn you better replace the knuckle and foam piece that goes inside,
    Apr 2021
    Ft Myers FL
    1983 633csi
    All the pic's I am seeing, it looks like the rubber bushing is one piece with the bracket ?? it that how it should be ? because my is def broken.
    Also Jclausen since this is my first e24 what part is the knuckle that you mentioned and the foam?
    tks
    Nov 2005
    Brookfield,CT
    '92 325IC '88 635
    tks
    Depending on your year and tranny type, they used slightly different pieces to make up the shifter mechanism. I believe the foam part that jclausen was referring to is highlighted in yellow below.
    '88 635, '92 325IC
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    Yep, those little mounting blocks have a rubber bushing with a steel sleeve to carry the shifter bracket plate. Your shifter support plate should still have the bolts and what's left of the bushings attached.
    I don't want to confuse this with inaccurate info, but there are actually two different versions of those shifter isolation bushing blocks that I've seen, but I do believe they are interchangeable. The later ones have a more squared-off shape. The earlier ones look like yours, with more of a tombstone shape:
    Early mounts
    Later mounts
    Save the manuals!
    '08 128i 6MT, '86 635CSi 5MT (B32, Motronic 1.3, WBO2, G265, 18# FW, 3.46 torsen)
    Past projects:
    '96 318iS, sold 4/23 '90 535iM, RIP 1/23 '90 535iA RIP 6/22 '91 318i, sold 7/19 '97 M3 sedan, sold 11/18 '85 735i, RIP 2/18 '92 325iC, sold 7/16 '91 318iS, sold 6/16 '84 745i, sold 10/14 '82 633CSi, traded 9/12 '90 325i, RIP '87 325 sold '89 525i, traded '87 325iS, RIP
  1. E39 E39 5 Speed Rear Tranny Mounts. NEW!
    By xpcgamer in forum Drivetrain & Transmission Parts
    Last Post: 09-07-2011, 07:52 AM
  2. Door Panel, Rogue Tranny Mounts, UUC Enforcers, Rear Seat Backs
    By mweinst in forum Exterior Lighting & Body Parts
    Last Post: 07-12-2009, 10:31 PM
  3. polyurathane front controll bushings rear shocks mounts tranny reinforcers
    By restricted in forum Suspensions, Springs & Shocks
    Last Post: 08-16-2007, 10:27 AM
  4. FS: UUC Tranny Mounts, Front/Rear Strut Braces, URI Crank Pulley
    By Mini-Bubba in forum BMW Parts For Sale
    Last Post: 04-02-2005, 04:05 PM
  5. busted rear auto tranny mount -WTF
    By ben dixon in forum 1991 - 1999 (E36)
    Last Post: 02-15-2003, 09:39 PM
