Results 1 to 6 of 6
Thread: 04 x3 auto shifting problems
    Apr 2015
    United States
    1986 bmw 325e
    Got a 2004 x3 2.5 with 5speed GM autotrans. 165,000 miles. It just started to experience longer shifts while going into higher gears while in Drive. I know its supposed to be lifetime fluid. But I also know nothing is lifetime. I have heard some people start having problems around 150K. Do you think a filter change and fluid fill would help or hurt it making it worse? Any help would be apricated. I'm Just about ready to spend a few hundred on fixing the oil leaks and servicing the vanos. maybe I should wait and see if the trany gets worse? any thoughts?
    Thank you.
    Jan 2016
    Ca
    2001 525it
    It would be a crap shoot on how the trans would react to the fluid change and when you change the fluid your only getting 5 6 qrts of oil out. Really the warning about the trans crapping out was on older cars, but still you never know what will happen, when I got my car at 100k I have change the fluid 4 time since and now I have 178k, the last change I did the fluid twice to get the more of the newer fluid in.
    Worldwide
    2004 X3 88 M3 83 323i
    Jclausen hit it on the head. Mine is at 180k and did it 80k ago but now afraid. Thinking of getting a used transmission and rebuilding and dropping that in.
    1983 S50 swapped 323
    1988 M3
    1997 z3 1.9
    2004 X3 2.5
    Apr 2015
    United States
    1986 bmw 325e
    Thanks for your replies. for some reason it seems to be shifting ok now. I guess I'll just wait and see.
    May 2012
    FL
    E83, E21
    I wouldn't think twice about several drain/fills within a few hundred miles of each other, with filter/seal on the final one. If there are any problems with the transmission, the old fluid is merely masking them; issues won't be caused by the new fluid. The slipping in the old days occurred because the fluid's lack of lubricity caused clutch pack wear, which then acted as a friction modifier keeping the clutches from slipping.
    Use Dex 6.
    According to my documentation, GM wanted the fluid changed every 45k miles, and in as little as 15k miles in "extreme conditions."
    E21 build
    BMW CCA 584213
    I buy socks from Amazon.
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    100 percent in agreement with this:
    Quote Originally Posted by dukedkt442 View Post
    Use Dex 6.
    Regards,
    Brian
    Cave Creek, AZ
  1. 2007 X3 Gearbox/ shifting problems
    By Sammy Po in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-17-2017, 03:25 AM
  2. 98 M3 Auto Shifting Problems--HELP!
    By SmokedBMW23 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-09-2010, 12:08 PM
  3. e30 auto shift problems
    By Night Rider in forum 1983 - 1991 (E30)
    Last Post: 02-24-2009, 01:47 PM
  4. 97 328i auto shift problem?
    By cool breeze in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-19-2005, 08:36 PM
  5. Auto Shift knob problem
    By IgotMy18s in forum 1991 - 1999 (E36)
    Last Post: 06-01-2003, 02:50 AM
