Results 1 to 23 of 23
Thread: Z3M parting out aftermarket parts
    Feb 2004
    san diego
    ...it depands
    Hi all,
    I'm in the process of parting out all aftermarket parts (except the blower) on my z3, so let me know if any of these items interest you.
    Not looking to gain anything, just want them to go to good homes where appreciated.
    Either pick up or shipping (92129) is fine. Thanks!
    - Chrome roll bars and the clear lexan wind deflector (a matching set, can be sold separately)
    - AEM WMI kit with a custom mount to SAP location, WMI filter, solenoid, and windshield fluid reservoir tapped methanol tank. $200 plus shipping
    - Two spare DMEs (MS41.1) with whatever the possible setting you need (even back to stock bin if prefered). No afr/ignition related tuning for liability reason (but with the wealth of knowledge on this forum, I'm sure you'll be able to figure out to do it yourself or I can help you to set up if you prefer)
    - Innovate LC1 AFR gauge with a wb sensor
    - A set of stock cat-back mufflers that has 3" chrome tips and cutout valves (closed style, vacuum) installed.
    - A set of new 2" vacuum cut-off valves (open style) with two solenoids/remote switches
    - Spring-loaded adjustable BOV
    - 3.33" & 3.66" vortech pulley (6-rib) with matching serpentine belt for VFE sc kit. - A direct swap Sold each plus shipping
    - Oil cooler cap (for oil filter housing). The heat exchanger and thermostat will come free with the cap (oil line hose, not included because you should probably get a new line for them).
    - SPL electric fan (30100400) with its own single temp switch and relay
    - E85 fuel pump with an assembly that has a new fuel level float sensor
    - Front strut bar
    - OEM Chrome shift knob (New) (If you own a z3 m, you will lose the light illumination with the chrome knob unless you modify it to transfer the lighting components like led and wiring from the z3m)
    - Aluminum thermostat housing $1 plus shipping
    - Canadian DRL light relay
    - More to come... Let me know if you see any other aftermarket-ish things that aren't listed here (but you see in the link below). The chances are they will most likely be taken off.
    All parts are shown in my build thread (if not, I can upload):
    https://www.bimmerforums.com/forum/s...ster-log/page2
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
    Aug 2014
    Canada
    1996 BMW Z3 1.9 Hellrot
    Interested in the roll bars with the deflector. Would you be comfortable shipping to canada? I would just need to know what the package weighs so that I can try to guess shipping cost.
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by caglar View Post
    I can ship them there. But it may be pricy.
    Each roll bar weighs about 4.5 lb. So the total should be about 10 lbs.
    If you have shipping access, you can send me a label to save on shipping.
    - Zach
    Dec 2004
    Parma Heights
    '00 Z3M, '06 Z4M
    Pics of the oil cooler setup? I am interested.
    Check out my M Roadster projects and DIYs:
    Cooling system part 1: https://youtu.be/ERqztIL1DPw
    Cooling system part 2: https://youtu.be/-DnclDkn2hI
    Power convertible top: https://youtu.be/KLYNqkCBh_M
    Head unit removal: https://youtu.be/LKe9fPKrAqE
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by Andryuha View Post
    https://www.bimmerforums.com/forum/a...8&d=1478327498
    Please note that the oil line and fitting are replaced now (it has non-metal-braided sleeve hose)
    https://www.bimmerforums.com/forum/a...9&d=1478329457
    - Zach
    Oct 2007
    VA
    00 Mshoe
    What SPAL fan? I'm interested depending on the model.
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by robb1887 View Post
    what spal fan? I'm interested depending on the model.
    spal 30100400
    Oct 2007
    VA
    00 Mshoe
    PM me shipped cost to 23314
    Iceland
    Z3 2.8, E39 540 & X5 4.4
    - E85 fuel pump with an assembly that has a new fuel level float sensor $50 plus shipping
    Is this a direct bolt in and a upgrade ? My fuel pump seems to have died.
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by DrWho View Post
    Hi, I actually changed my mind about selling the fuel pump for the future use. Apologies.
    - Zach
    Iceland
    Quote Originally Posted by nevan View Post
    No worries, best of luck.
    Jul 2021
    Toronto
    1999 BMW M Roadster
    Hi - It's not listed as some of your parts for sale, but curious if you wanted to sell your LeatherZ armrest and ZHP shift knob?
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by frigga View Post
    The arm rest is staying. Sorry.
    - Zach
    Feb 2004
    san diego
    ...it depands
    Photos for the additional items added above:
    https://www.bimmerforums.com/forum/s...4#post30714424
    - Zach
    Feb 2004
    san diego
    ...it depands
    The ZHP knob is long gone. But I just found a new chrome knob in the garage (that I didn't know I had). Let me know if you want that instead.
    - Zach
    Sep 2012
    Nebraska
    1998 M Roadster,'07 328i
    I will take the strut bar and the thermostat housing. PM Sent.
    Mar 2022
    Saltash, Cornwall, UK
    BMW Z3 2000 2.2i
    I replaced the foot well speakers and stupidly lost the bonnet pull handle. Any ideas where I can source a replacement please?
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by sydjai View Post
    I just saw your post today. Sincere apologies for the late reply. Do you still want them? If so, PM me your your address with ZIP so I can give you the shipping estimate.
    - Zach
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by nige61 View Post
    I bet you can find one on eBay easily. Be sure to get the correct driver side version for your country (check with realoem.com for part number). Good luck!
    - Zach
    Mar 2022
    BMW Z3 2000 2.2i
    Thank you, much appreciated. yes ebay for around £12.
    McLean, VA
    02 MC, 01 MR, 99 Z3C
    Doug Whalen was selling the last of his stock of RHD aluminum hood pull levers. He might still have a few. Outstanding product.
    https://m.facebook.com/story/graphql...I4NDE5MzIyMTA2
    Kelvin
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    Still have strut bar?
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by TexaZ3 View Post
    It's gone now. Sorry.
    - Zach
  1. BMW 540it 6sp for parts many aftermarket parts - No Longer Available
    By hooningsidewayz in forum Whole Parts Cars
    Last Post: 05-09-2017, 12:00 PM
  2. parts search aftermarket parts
    By shogun in forum 1978 - 1987 (E23)
    Last Post: 02-12-2016, 08:07 AM
  3. Replies: 1
    Last Post: 09-16-2011, 12:22 AM
  4. F/S Aftermarket parts for E36 & E36 M3 ( check it out )
    By bmw332is in forum BMW Parts For Sale
    Last Post: 09-15-2001, 05:21 PM
  5. aftermarket parts for 328Ci
    By Disturbed Kat in forum 1999 - 2006 (E46)
    Last Post: 05-01-2001, 04:41 PM
