Hi all,
I'm in the process of parting out all aftermarket parts (except the blower) on my z3, so let me know if any of these items interest you.
Not looking to gain anything, just want them to go to good homes where appreciated.
Either pick up or shipping (92129) is fine. Thanks!
- Chrome roll bars and the clear lexan wind deflector (a matching set, can be sold separately)
- AEM WMI kit with a custom mount to SAP location, WMI filter, solenoid, and windshield fluid reservoir tapped methanol tank. $200 plus shipping
- Two spare DMEs (MS41.1) with whatever the possible setting you need (even back to stock bin if prefered). No afr/ignition related tuning for liability reason (but with the wealth of knowledge on this forum, I'm sure you'll be able to figure out to do it yourself or I can help you to set up if you prefer)
- Innovate LC1 AFR gauge with a wb sensor
- A set of stock cat-back mufflers that has 3" chrome tips and cutout valves (closed style, vacuum) installed.
- A set of new 2" vacuum cut-off valves (open style) with two solenoids/remote switches
- Spring-loaded adjustable BOV
- 3.33" & 3.66" vortech pulley (6-rib) with matching serpentine belt for VFE sc kit. - A direct swap Sold each plus shipping
- Oil cooler cap (for oil filter housing). The heat exchanger and thermostat will come free with the cap (oil line hose, not included because you should probably get a new line for them).
- SPL electric fan (30100400) with its own single temp switch and relay
- E85 fuel pump with an assembly that has a new fuel level float sensor
- Front strut bar
- OEM Chrome shift knob (New) (If you own a z3 m, you will lose the light illumination with the chrome knob unless you modify it to transfer the lighting components like led and wiring from the z3m)
- Aluminum thermostat housing $1 plus shipping
- Canadian DRL light relay
- More to come... Let me know if you see any other aftermarket-ish things that aren't listed here (but you see in the link below). The chances are they will most likely be taken off.
All parts are shown in my build thread (if not, I can upload):
https://www.bimmerforums.com/forum/s...ster-log/page2
2000 Z3 M Titanium Silver / Imola Red+Black Nappa
2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
Since 1987 12 euros / 2 kdms / 2 jdms
- Zach
Interested in the roll bars with the deflector. Would you be comfortable shipping to canada? I would just need to know what the package weighs so that I can try to guess shipping cost.
- Zach
Pics of the oil cooler setup? I am interested.
Check out my M Roadster projects and DIYs:
Cooling system part 1: https://youtu.be/ERqztIL1DPw
Cooling system part 2: https://youtu.be/-DnclDkn2hI
Power convertible top: https://youtu.be/KLYNqkCBh_M
Head unit removal: https://youtu.be/LKe9fPKrAqE
https://www.bimmerforums.com/forum/a...8&d=1478327498
Please note that the oil line and fitting are replaced now (it has non-metal-braided sleeve hose)
https://www.bimmerforums.com/forum/a...9&d=1478329457
- Zach
What SPAL fan? I'm interested depending on the model.
- 1of1 rebuild (build thread) -
- Wanted Car items - FS: PnP aftermarket alarm details -
- Coupe Custom Subwoofer box - FS: Z3 Coupe LED 3rd brake lights -My Website for DIY content and parts: Double Bee Garage
PM me shipped cost to 23314
- E85 fuel pump with an assembly that has a new fuel level float sensor $50 plus shipping
Is this a direct bolt in and a upgrade ? My fuel pump seems to have died.
- Zach
Hi - It's not listed as some of your parts for sale, but curious if you wanted to sell your LeatherZ armrest and ZHP shift knob?
- Zach
Photos for the additional items added above:
https://www.bimmerforums.com/forum/s...4#post30714424
- Zach
The ZHP knob is long gone. But I just found a new chrome knob in the garage (that I didn't know I had). Let me know if you want that instead.
- Zach
I will take the strut bar and the thermostat housing. PM Sent.
I replaced the foot well speakers and stupidly lost the bonnet pull handle. Any ideas where I can source a replacement please?
- Zach
- Zach
Thank you, much appreciated. yes ebay for around £12.
Doug Whalen was selling the last of his stock of RHD aluminum hood pull levers. He might still have a few. Outstanding product.
https://m.facebook.com/story/graphql...I4NDE5MzIyMTA2
Kelvin
Still have strut bar?
E36/8 2000 M Coupe Cosmos Black/Black
Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
- Zach
