These were OEM on my car (a non BMW) which I purchased with 142 miles on it.
When I picked up the car in December I had them put on all seasons and these have been in my storage area.
I am in no rush to sell these so I won't take a crazy low ball offer.
I will not ship these tires.
Local pickup near Mahwah NJ only.
These tires are flawless as you would expect with 142 miles on them. I pulled one out of storage to take the pictures - no need to take pictures of all 4 but feel free to inspect them when you pick them up.
Please double check size to ensure compatibility with your car.
Style: Blackwall
Load Range: XL
Serv. Desc: 96Y
UTQG: 280 A A
The Potenza S001 is Bridgestone's Max Performance Summer tire developed as Original Equipment for premium high-performance sports cars, coupes and sedans. The Potenza S001 is designed to combine low rolling resistance efficiency with maximum sports performance in dry and wet conditions. However, like all summer tires, they are not intended to be driven in near freezing temperatures, through snow or on ice.
The Potenza S001 features an asymmetric design combining a large outboard shoulder, interlocking tread blocks and a central circumferential rib to enhance dry road steering response, high-speed stability and cornering precision. Notches in the shoulders expel water to the sides while high-angle lateral grooves in the intermediate ribs pump water into the wide circumferential grooves to help resist hydroplaning.
The tire's internal structure features a lightweight belt package consisting of twin steel belts supported by a spirally wrapped aramid/nylon cord reinforcement that reduces rolling resistance, enhances ride quality and ensures high-speed durability. Active rubber inserts in the sidewalls near the bead areas tune vertical sidewall stiffness to blend cornering grip with ride comfort, as well as increase longitudinal stiffness to generate straight-line braking forces.
Please post an asking price.
GLWS!
88M3 AW 43k miles Project FS
