Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Thread: Who's running 275s on the E36 chassis?
  1. #26
    Aug 2012
    Central, MD
    1995 M3
    My current baseline is:
    F: 5.3"
    R: 6.1"
    27mm front sway, OEM rear.
    But I run a high ride-height because of this one turn. I have plenty of clearance for normal turns.
    I'm rethinking that this year, I think I'd be much better off lowering another 1/4-1/2", and just slowing the fuck down on this turn so I don't rub.
  2. #27
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Is it your rear rubbing correct? Everything I was seeing mentioned a 1/4 to 1/2" rake. Are you looking to keep the front asis aand lowered the rear further or both?
  3. #28
    Aug 2012
    Central, MD
    1995 M3
    I can go to full spring compression on both front and rear, no tire rubbing, so my ride height is to prevent full spring compression on that one turn.
    I am on the edge of throttle-on oversteer on corner exit, but I rarely worry about getting to full throttle quickly.
    I'd like to lower both front and rear, but yea, also try 0.6" rake.
    (I am getting inside wheel spin with 850/1000 springs compared to the 750/900, but I think that's the diff clutches getting tired.)
  4. #29
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I assume you read about Hard’s experience with tracking wider tires than 255. Flares would be best. I run 275 rears on 17x9, have seriously rolled and pulled my fenders, raised the ride height about as far as I can, and changed to 650 lb rear springs but it still is not ideal. I have a set of flares and 17x10s to install.
  5. #30
    Springfield, IL
    Aeronaut and I are both flared running 9.5 -10" wheels currently.
  6. #31
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by olemiss540 View Post
  7. #32
    Spanish Springs NV
    17 Sprinter, 94 325is
    Quote Originally Posted by aeronaut View Post
    F: 5.3"
    R: 6.1"
    Where are you measuring this height from?
  8. #33
    Aug 2012
    Central, MD
    1995 M3
    Jack points
  9. #34
    Spanish Springs NV
    That's what I thought. Thankyou.
  10. #35
    Springfield, IL
    Ok, heres what I look like at 5.1F/5.7R measured at the jack point without pads.
    Thinking raise the front another 0.25" or so? Would reducing the rake help with rear traction under braking? With my tires being 1" smaller in diameter that aeronaut, we are probably in the same ballpark on ride heights, althought my springs are softer at 550F/650R.
  11. #36
    Aug 2012
    Central, MD
    1995 M3
    Looking good!
    It would help a teensie bit with rear traction in braking. IMO, rake (between 0.2" and 1") is a small knob to tweak.
    Did you set ride height with your weight in the driver's seat?
    I'd send it as is. See how it handles. Put some zip tyes on the damper shafts to see what travel you're getting to see how close you are to coil bind.
    Here's kinda what mine looks like.
  1. Anyone running without insulation? E36 chassis
    By Cobra1956 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-31-2017, 04:58 PM
  2. E36 Wanted e36 chassis in Indiana!!!
    By Luke Stutz in forum Whole Parts Cars
    Last Post: 08-11-2012, 03:48 PM
  3. E36 Wtb rollers to put on e36 chassis: sfbay
    By wanganstyle in forum Wheels and Tires
    Last Post: 12-27-2010, 05:12 PM
  4. E36 S54 plug and play swap harness for e36 chassis
    By wanganstyle in forum Engines, Performance Parts & Software
    Last Post: 09-24-2010, 12:35 PM
  5. how many of you are running 275's all around on your e36?
    By autocross97 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-19-2008, 05:33 PM
