Results 1 to 12 of 12
Thread: BMW 318i A/C Pressure Senor
    Apr 2021
    Minglanilla, Cebu, PH
    BMW 318i
    Hi everyone. I'm having problems with my A/C. There are times the compressor clutch won't engage. There are times it will. The compressor clutch engages randomly, I have to play around with my A/C by turning it off for a while and then on to see if it will blow cold air. And yes, I do have the snow flake button on everytime. The compressor has just been changed recently as well.
    I just had it scanned by an ODM II tool and it says that there are problems with my "IHKA: AUC Sensor" and "IHKA: Pressure Sensor".
    I would like to know the location of these two and what it looks like so I could probably have a look and replace them.
    Thanks!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    we need more info, built year/month, EURO model, US model, Japan model or whatever. Engine M43, N42, N46, I even found a Phil spec 318i E36 . Use the VIN http://bmwfans.info/parts-catalog
    NW suburban Chicago
    hiss by my window
    Check pressures. This could be normal operation and the result of incorrect charge.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The AUC is the sensor that senses air pollution. If the IHKA is in the auto-recirculate mode it will shift to the recirculate mode.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Quote Originally Posted by MarcoZandrini View Post
    And it's very common on a 15+ vehicle to have that fault, but it doesn't keep the A/C from working properly unlike low pressure.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Apr 2021
    BMW 318i
    Hi Shogun, I have a BMW 318iA 2000 Euro model with M43 engine.
    Apr 2021
    BMW 318i
    Hi ross1, I have had teh pressures checked last March and there seems to be no problem with it. I also had it topped up on that same day. The compressor ran for half a day and then started to stop again.
    Apr 2021
    BMW 318i
    Quote Originally Posted by Chriskrinlge View Post
    Thanks!
    Stupid question, but is the "Pressure Sensor" also the "Pressure Switch"? I mean, I've been looking online ang typing specifically (Pressure Sensor) but the results are either unrelated or "Pressure Switch".
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I believe the 2 terms refer to the same part. It’s a pressure switch: either you have enough pressure or you don’t.
    dworthy's Avatar
    Nov 2010
    +1
    Pretty much what everybody is saying is to head down to a shop and see about getting your A/C system checked out for proper pressure/fill.
    Darin
    Current:
    Past:
    M-Flight Member
    Apr 2021
    BMW 318i
    Thanks!
    Hi everyone,
    I figured out what the problem was. The temperature sensor located under the fog light was loose. After, making sure it was connected properly, the a/c started working normally again.
    FYI before posting the a/c issue I already did most of what you guys recommended. Such as: checking the pressure, looking for leaks, taking it to a mechanic but sadly all it did was cost me and did not even give results. Kinda funny I resolved it myself ahaha.
    Anyway, thank you all for your help! I really appreciated it!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Glad it worked out for you. Yes, the ambient air temperature sensor prevents the compressor clutch from being engage is the sensor tells the climate control module that it’s cold outside. Them Germans.
  1. 1991 BMW 318i E30 Oil Pressure
    By kjandir1 in forum 1983 - 1991 (E30)
    Last Post: 04-21-2015, 05:50 PM
  2. 1992 BMW 318i Sedan No ac but holds pressure?
    By bladeboy935 in forum 1991 - 1999 (E36)
    Last Post: 09-03-2011, 04:35 PM
  3. BMW 318is E36 Coupe "Alpina look"
    By Gazmate in forum BMW Cars For Sale / Wanted
    Last Post: 02-02-2003, 03:50 PM
  4. For Sale: 1995 BMW 318is
    By alexd in forum BMW Parts For Sale
    Last Post: 06-28-2002, 09:04 AM
  5. For Sale: 1995 BMW 318is Super Clean
    By SlammedBMW in forum BMW Parts For Sale
    Last Post: 01-30-2002, 04:03 PM
