Hi
First sorry if this has been discussed to death but have not been able to find an answer that's clear.
Are all BBs RS centers the same? Example 003 and 073 (16" 4x100) centers are the same its the inner and outer barrel that's make the difference?
even if some 4 lug centers are the same, alot of bbs wheels ive seen have the type number marked on the center. im sure there are some things that swap around directly, but is most likely not going to be whatever centers your trying to swap around.
try r3vlimited.com or hondatech for 4 lug wheel info, e30's e21's an 2002's are the only 4 lug bmw's, an only e30s are common... theres a billion econoboxes that can fit wheels you want,
