Hi guys,
This is my first time posting on a forum like this ever, so my apologies if something is out of orderly fashion.
A little background about me:
I'm currently a 23 years old student and living in The Netherlands and I forever wanted a BMW e21 that spoke out. So I bought one that was basically a Rust bucket (315 with m10b16) and started working on it. I could never figure out what type of engine I liked so I snooped around a lot and actually bought (and sold) a m10b18 and m42b18. Then I found a thread of some guy, cannot remember his name, but he swapped a M60B40 into an E21, and i liked it very much. So i decided to do that too. I bought myself a M60B30 with manual gearbox, but i still was snooping around to make it even sexier. Then I came across what i thought was the best looking combo ever, an M62B44 with a XKR supercharger. The build is somewhere on this website, will post a link if i can find it.
So i went to look for a supercharger set from an XKR, and actually found one very cheap. I bought it, but could not, for the life of me, find an adapter kit. So i reached the whole point of this post:
I made one myself and I was thinking of making a couple to sell locally or globally for anyone interested. I wanted to do something in return for the community as many of the posts inspired me to buy and build my own BMW.
Currently I'm extremely busy and I think this summer, most of the work will be finished for sales etc. If anyone wants details or something just PM or add to thread. I will reply however i can.
I hope someone is able to put the kit to good use.
Sorry for the long story, but thanks for the read!
Good stuff! I'm currently looking for some adaptor plates to build a hi-ram (holley-style) manifold for my TU. Already running with a centri but the Jag setup is definitely cool.
S/C 2003 540i Msport
Nice. Toolman did something similar many years ago. Not sure if he is making kits though. Look at his belt wrap on the front pulley. Really help prevent slip. I like your integrated front extension for idler pulley support.
https://www.bimmerforums.com/forum/s...harger-install
Ill take one, depending one price.
send me a pm with what you are asking for it.
Thank you for the kind words.
The reason why I altered the idler pulley was that i didn't like the timing case mounting.
In my design process, I saw that the belt runs - from the front view - clockwise. Meaning that the idler pulley in a different configuration is always under extreme tension. Now it runs on the slack side. The second reason was that the waterpump pulley has too little grip in the other configuration.
Besides that I've also designed a pressfit mount to mount on the snout, on that pressfit any pulley size can be attached. Currently I've made 4 pulley designs that are scaled for M60B30/B40 and M62B35/B44. B46 is optional, havent designed that one, but (nearly) any size is possible.
i'll keep updating everything, but inserting images and replying to PMs seems troublesome. I'm not sure if i'm doing something wrong..?
88M3 AW 43k miles Project FS
Looks good I'm running a toolman kit.. there seem to be a few enthusiasts looking to supercharge there V8's out there so you could see some interest.
1999 540 Auto with Eaton M112 supercharger
Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
That is really cool. How is it running? I'm very curious how you experience the kit. Haven't been able to test my engine just yet, so any experiences are welcome. Do you run it with the OEM jaguar pulley?
Gazzed07
I could send you a DWG file for the intake manifold surface if you like? Really easy for cnc cutting
[QUOTE=dumry;30669345]That is really cool. How is it running? I'm very curious how you experience the kit. Haven't been able to test my engine just yet, so any experiences are welcome. Do you run it with the OEM jaguar pulley?]
Its running very well and I am happy but it could be better and safer with a more competent ecu. I did change the jag pulley for a smaller size 2.8" springs to mind.
I also blew up my first engine due to ring butting on cyl 1 I rebuilt it with another block and decompression rods.
[QUOTE=Kenny1958;30669446]141mm rods? Sorry to hear about blowing the first engine up. But we learn as we go I guess haha. High combustion temperatures (and detonation) are one of my worst headaches as of this moment, so the second adapter model will probably feature some ports for direct port methanol/water injection. I have no experience what so ever with methanol, but the results always look very promising. The pulley I designed for a B44, what i assume you have, has a diameter of 2.75", so i'm guessing it's nicely matched.
I was planning to use speeduino as programmable ECU, and create/source maps for all m60 m62 variants (or at least create a base map) using lineair scaling.
[QUOTE=dumry;30669509]Yeah 141mm around 8.5-1. I'm afraid my knowledge of tuning is very poor but my daughters Dutch boyfriend is doing computer coding at university he might be able to help me understand a little more but they are stuck in Sterling in Scotland at the moment due to Covid and I haven't seen them in a yr now.
The quick change pulley was bought from USA when I bought my kit from toolman I cant quite remember the price but it was affordable enough.
Hi, I'm looking for the adaptor kit as well. How is the kit holding up? and is it available?
Hi dumry, do you still have the DWG file for the intake manifold surface? I'm looking at the same set up. any help or assistance would greatly be appreciated. especially from Down Under where it's limited for these thing and it's expensive too due to the freight and conversion rate. cheers
Hi, there are some fitment issues to work out, but those issues are only minor. I can send you a DXF/DWG file for the BMW side. In the summer I will be finishing up the wiring and then I will test run the engine, so I will give an update then.
I'll PM you the BMW side file
In for updates.
650hp 10 X5///M5
PERFORMANCE:JB4 w/ meth, stage 2 tune, wrapped downpipes, custom intake
INTERIOR:AVIN 10.25" screen, Blackvue 550 dashcam, 7" tablet for JB4 logging
EXTERIOR:Niche staggered 20's or AC Forged staggered 22's, H&R 2" suspension, LED AE, CF front splitter
325hp 98 BMW 740iL6
PERFORMANCE:///M5 6spd swap, iron sleeves, L/W Teflon coated & silicone impregnated pistons, Sealed Power rings, 3 angle valvejob, P&P head, perf cams, electric fan, CF intake tube w/aluminium heatshield/wrapped MAF tubing, Magnaflow 14816'd, Eaton M112 in-work
INTERIOR:Android Dynavin, hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D monoblock, CF silver trim, 5% tint
EXTERIOR:///MPar staggered 19's, H&R Stage 2/Bilstein HD, custom notched bumper, Shadowline trim, 750iL brakes w/ Axxis pads
190hp 97 328ci
PERFORMANCE:Single mass flywheel, ///M3 clutch
EXTERIOR:Z4///M staggered 18's, rolled fenders, tinted markers
Well done, nice adapter plate!
Is this a one piece design, what material did you use?
The bloc before machining must be huuuuge!!!
I'm currently studying adapting the Cadillac m122 unit on m62b44.
I wanted to know if you had an idea of the damper pulley offset with the first inlet port?!
EDIT : maybe I'll come see the car, it seems I live 48min away from your city!!
Subscribed. I am a newbie when it comes to rebuilding engines, but I have a M62TUB44 that came out of my X5 project and want to rebuild it as a M60B44 and use it for a new build of some sort. From what I read, forced induction is probably the only way that V8 is putting out 400 hp (a target number I’ve got in my head for some reason).
Current BMW
2002 E53 X5 4.6i (4.4 to 4.6 swap)
Former BMWs
1996 BMW Z3
1998 BMW E36 M3 Sedan
2004 BMW E46 M3
Cadillac m122 has already been fitted.
I could sell adapters, but there is so much required to make it work, you should wait for me to release the entire kit.Attachment 704123Attachment 70412420220112_210638.jpg
Fully bolt on, but your engine will have to be fully disassembled to regap the rings, or it will last one week. The engine, that is.
Not enough room for past/present garage
Wow that looks like a beast. What troubles did you find when fitting it? One problem I noticed with the belt was that the alternator bolt is very close to hitting the belt, so that needs deepening out.
I'm sorry if i have not replied to any messages last year, it has been crazy busy. Some minor steps have been made in progression to the full supercharger build. I only have some scarce weekend nights to work on the car and engine. So progress is slow. Currently I have been working on adapting the subframe of a e34 540i to fit an e21. Because of the power steering and bigger brakes and 5x120 hubs. Since the v8 is probably a lot heavier than a m10, certainly with the supercharger, powersteering has become a must. Will post pictures later on.
Yes the block was pretty huge, but then again, the costly part of machining is not the material, its the labour and machine running costs. Material is something like alu 5000 series, the machinist told me to use it rather than 6000 or 7000 series due to the heat cycle properties and corrosion. So thats that.
I have also decided to make the adapter plate public available. I will upload the CAD files somewhere this year when I have more time. The main issue is costs. Many people have asked me to give them a quote for the costs of a complete kit without the charger itself, but almost all don't actually follow through. I understand that the costs are high, but since the part is relatively complex, it is difficult to bring the costs down. Separating the left and right bank could help ease the costs, but this is only marginal. Since the fixation for the current design is already made, it is actually cheaper to continu milling them like it is now. Costs are in total around 1000 eu to 1100 eu. sharing the CAD file online could help some of you maybe for figuring it out with a local machinist for cheaper. However, I do note, that the design is not perfect, the fitment with engine and supercharger is good, but some manual machining of the tensioning pulley is likely required, although this is not difficult.
It might also be possible to actually 3d print certain components, such as the supercharger and tensioner pulley. Although this I have not tried, I will do in the future.
How much further above the heads does the supercharger and intake sit? Trying to figure out how much extra room at the top is needed for a setup like this.
From the top of the supercharger assembly to the top of the heads is at least 15 cm, which is about 5.9 inch. You'll probably need a bit more, considering heat and vibrations and all.
I've attached another picture regarding the depth, but this depends on your setup. In my case i've used an adapterplate to adapt the original bmw throttlebody to the supercharger.
Did the cad files ever find their way online or is it still a wip?
