Results 1 to 11 of 11
Thread: e39 525d 2000, Is there a way to revert remap to stock for testing and save the remap
    Feb 2021
    Slovenia
    Astra H GTC, 91 Camaro
    Hy,
    My car is e39 2000 525d, I had bought it remapped and I don`t know how it was remapped.
    I have some problems, with high consumption, injectors are sometimes loud, sometimes quiet like new -not temperature releated or releated of how long I drive it.
    Is there a way to upload stock map to ecu and save the exsisting map, so I can upload it back if I find out that this map is good?
    I have K+DCAN cable and INPA, ISTA+, winKFP, NCF dummy and expert, BMW coding tool, Tool32,...
    I feel comfortable doing it if I get directions...
    Thank you
    Feb 2021
    Slovenia
    Would update with sp-daten in winKFP remove the remap?
    Feb 2021
    Slovenia
    Ok, I have sp daten for my car, I have the tutorial for update, now I need to know if this will remove the remap and if I can save the remap somehow to restore it back later when needed.
    Jul 2004
    Houston, TX
    36 Cylinders
    If you overwrite your maps with WinKFP, you will lose previous maps. However I've seen how bad some of those tunes can be, so it may be better to get a better tune.
    Best case is to use MPPS v16 (or even Galletto 1260 program with your k-dcan) or similar to read the data, and then rewrite the same ZB using WinKFP. Save everything so you don't have to lose data.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2021
    Slovenia
    Thank you, will try. I have try to read flash with BMWflash.exe, but it doesn`t work...
    About the map... I must repleace the MAF sensor first then I will try stock map if no improvement... But my problem is consumption 8.5L/100km on open road if I drive it carefully, injectors are sometimes loud as hell, sometimes quiet as new, it`s not temperature releated or trip distance releated...
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by kajaalyo View Post
    BMWflash.exe is for Siemens petrol ecus of that era. It will not work.
    Loud injectors on diesels have to do with timing changes and improper pilot injection.
    -Abel
    Feb 2021
    Slovenia
    Thank you for this clarification.
    improper pilot injection -this is also ajdusted with remap right?
    and by timing you mean injection timing, not the chain timing right?
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, pilot injection for common rail can be adjusted in map, with good knowledge, or no knowledge at all.
    Yes, for timing, I mean injection timing. Most often tuners just add degrees of advance (or highlight and add percentage) without any real reason or to the wrong set of maps.
    So I think you are on the right track to go to stock, and then compare.
    -Abel
    Feb 2021
    Slovenia
    Ok, I have the file. Had read ecu with Galletto 1260...
    Can now I update ECU with sp daten and winkfp and still use this file later? or not?
    Jul 2004
    Houston, TX
    36 Cylinders
    If you reflash with the same version (same ZB) then you can use this file later, yes.
    -Abel
    Feb 2021
    Slovenia
    I changed the injectors with factory rebuilt by bosh and it`s good now.
  1. E39 E39 1997-2000 Driveshaft w/ center bearing Bavarian Auto Recycling
    By Damaskus325 in forum Drivetrain & Transmission Parts
    Last Post: 08-26-2009, 11:32 PM
  2. E39 OEM E39 M5 2000 Hella clear tails
    By razahyde in forum Exterior Lighting & Body Parts
    Last Post: 09-23-2008, 11:43 PM
  3. E39 SRS (air bag) reset tool wanted E39 MY 2000
    By 540iman in forum Engines, Performance Parts & Software
    Last Post: 03-04-2008, 10:26 PM
  4. E39 FS: e39 1996-2000 DEPO crystal non-LED tail lights
    By PJB in forum Exterior Lighting & Body Parts
    Last Post: 10-17-2007, 01:32 PM
  5. E39 97-2000 Celis Upgrade Question
    By killcrap in forum 1996 - 2003 (E39)
    Last Post: 06-05-2005, 10:27 PM
