Just purchased this vehicle. Front brakes drag when hot. Anyone ever seen this before.
How's your brake master cylinder? When was it last changed?
1988 e28 535is...sold
Had the same problem in a 84 533i. RF caliper would drag when hot, at first I thought it was the transmission clutches or even an inverted sprag clutch... It was the caliper. Just letting it sit for a few a little while and it was back to normal, or a firm tap on the brake pedal while it was moving would usually unlock it. I would try flushing your brake fluid in the system if you don't know when it was last changed, may fix the issue, otherwise a caliper rebuild or replacement. Buy now while prices are still decent and they are available.
Had the same issue on my 84 533i. It is 100% the brake master cylinder, as thrty8street suggested. It's not a caliper issue.
