You will have to run a 12 gauge wire from the black block to a 30 amp inline fuse to the positive battery terminal post (see pic below).
In the pic below I had to use the y jumper setup for the main relay because I believe I have an ongoing issue which I believe is coming from the fuse box. I tried different 5 pin main relays and none of them seem to work. I would only get crank but, no start (no fuel, no spark). Maybe I have the wrong relays? I dont know, I'll figure it out later.
Anyways, I cranked the car up today and it starts and runs! Engine sounds smooth as butter! Feels like a new car! Motronic 1.3 FTW! I have not test drove the car yet. I have to do some cleaning up and put in the radiator and other stuff. I'll figure out how I'm going to mount the ecu and relays in the glove box later.
Sent from my SM-A205U using Tapatalk
Wanted to give you all an update on the car. I took the car on several trips and the car runs and drives great with the motronic 1.3 conversion. It's waaay better than the old 733i harness and components. I'm very pleased.
Please I'm me about conversion were getting out buts kicked
Hey call me or email . We have questions about the conversion
Hey, what do you wanna know about the conversion? How may I assist?
Thanks, its a m30b34 motor out of a 1985 735i. I was running 733i wiring electronics on the 735i motor. The motronic 1.3 is way more superior over the old electronics. I have more toque, the motor is more aggressive and responsive and its reliable! I've been driving with this setup and its awesome!
Update: I fixed my battery drain issue that I have been dealing with for about 10 years now. I tried multiple 5 prong bosch/aftermarket relays and they didnt work. The car would crank but, would not start. I was doing some research and I decided to purchase a BMW DME relay and give it a shot. The car fired right up and has no battery drain issues when you leave the car off!
Been driving the car everyday with no issues! The Motronic 1.3 setup is reliable and dependable!
This is really good stuff. Is this possible to work on a euro M30B34 E24?
