Results 1 to 9 of 9
Thread: Loud Buzz/Motorlike sound coming from the dash E36
    Jan 2021
    Montreal
    1998 323is
    I’ve had my E36 for a month now, its a 98 323is auto with 89k miles. I live in the northeast so its COLD. When I start the car on really cold mornings (-10C/14F or lower) the engine sounds fine. But when I start driving, I hear this really loud Buzzing almost like theres a Go Kart behind my dash board. Its mainly on the passenger side. It goes along with the motor, meaning at a full stop it doesnt make noises, but when I accelerate it like “accelerates” and gets louder. It really sounds like a crappy civic with no exhaust or a lawnmower or a gokart. Its less rattly thoz
    It isnt the engine because it purrs like a kitten and it comes from behind the engine. Id say maybe close to the firewall or even behind it. Ive read it could be the secondary air pump.
    Did you guys ever felt this? If so what was it and how can i fix it?
    Jun 2010
    NY
    1997 328i
    SAP is a good guess, if the valve that allows the SAP to push air down the exhaust manifold is not closing then when you drive the exhaust will suck air through the SAP and effectively drive the motor in the SAP. This will also ruin the SAP.
    Jan 2021
    Montreal
    1998 323is
    Yes thats what I thought, however at idle its silent, then at around 20mph its starts and after 10-15 mins when the car is warm it disappears. Im truly puzzled.
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Sounds like you have a small exhaust leak at the header ends. It happens when it gets really cold out on my car as well.
    May 2017
    Owings, Md
    1998 328i
    Since it starts and stops with motion, I am guessing that the heat blanket is sagging onto the driveshaft.
    Jan 2021
    Montreal
    1998 323is
    Ok so i figured out that it starts at 20mph but also is augmented when I turn the wheels to the left and stops when i turn them to the right. Even more puzzled. It does stop when the motor is warm.
    Jan 2021
    Montreal
    1998 323is
    UPDATE: front right wheel bearing is gone, will replace it at the same time I replace the front lower control arms.
    Nov 2013
    Oneida, NY
    Wheel bearings won't have any sound connection to the engine getting up to temp. However, power steering pump problems would. Unless you mis-heard
    Jan 2021
    Montreal
    1998 323is
    Im pretty sure the bearing isnt greased properly and makes the noise until the bearings and whatever grease they have gets to temperature. But yes will definetely bring it to my mechanic for a true diagnostic
  1. Very loud, high pitched sound coming from engine bay (N55)
    By MozartE90 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-27-2020, 10:49 AM
  2. Whistling sound coming from Engine BMW E36 320i
    By Beamertime in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-08-2011, 11:38 PM
  3. Weird knocking sound coming from the back e36 325is
    By Dsking85 in forum 1991 - 1999 (E36)
    Last Post: 04-07-2008, 03:22 PM
  4. Loud intermittent screeching sound coming from right-rear wheel
    By MrSandman in forum 1992 - 1999 M3 (E36)
    Last Post: 05-25-2007, 02:08 PM
  5. Loud intake hiss sound coming from throttle body area, ideas?
    By TRGfunds in forum 1991 - 1999 (E36)
    Last Post: 11-25-2005, 12:54 PM
