hi everyone, I have a no start situation and I wanted to verify the starter. Normally I would just excite the solenoid wire and see if the starter cranked. In this car however the starter is real difficult to get too so I planned to use the starter relay. I have been searching for this relay for two days. Previous posts suggest that it is under the hood under the two ECUs. When I pull the two ECUs ou there is nothing in the bottom of the white box. What am I missing. I did not disconnect the little fuse block or ECUs. Thanks for any help you can offer
What is exactly happening
