Im pretty new to the E36 platform.
I just picked up a hardtop for cheap that needs a little bit of work:
Its missing the C-pillars
One of the contact sensors is broken
The seal around the rear is loose in one area
Where is a good place to find these parts?
I got the hardtop installed but I've noticed that it sits higher on one side.
There is a dedicated vert subforum. You'll get a quicker answer there.
Good place to find parts is the dealer. Seals are very expensive though.
You can see the side pins have threads and a locking ring on them i.e. they can be adjusted. Adjust accordingly to make both sides sit evenly.
1998 BMW M3 3.2 Cabrio Alpinweiί III on Schwarz German spec 1 of 12
SMG SRA PDC AUC OBC GSM HK UURS IHKA FGR MFL
IG: https://www.instagram.com/iflok/
As M says.
I have sensors if needed
410-967-6170
