2005 325iT
So far I have replaced:
Purge Valve
DISA Valve O-Ring
Cleaned ICV and Throttle Body
Upper & Lower Intake Boots
CCV System (hoses etc.)
Valve Cover Gasket
New BMW Oil Cap
New BMW Gas Cap
DMTL Pump
This helped me pass SMOG awhile back, but after a 2nd smoke test with no visible leaks and replacing the DMTL pump to make sure it wasn't malfunctioning I still had 3 codes come back after about 300miles after clearing codes: P0440, P0442, P0456
At this point I don't know what else to do. There's charcoal canister and a few lines that connect the canister and the DMTL pump in the rear but if no smoke was visible I don't know if replacing those lines will solve it.
What's left to look at in this car?!
We had an e46 that was leaking from the brake booster and smoke was coming from under the dash
