Results 1 to 25 of 32
Thread: PSA: Check your throttle cable bushing
    Feb 2009
    Mills River, NC
    95 M3 coupe, 97 M3 sedan
    Earlier this week I pulled away from the auto parts store into traffic. The car accelerated like normal, then when I lifted off the gas pedal the engine went to idle and wouldn't rev at all. Pushing the pedal did nothing. I coasted to a stop in a neighborhood, popped the hood, and verified that the engine reacted to inputs at the throttle body linkage. Since the problem was between the pedal and the throttle body I assumed the throttle cable might have broken. I called a tow truck. Fortunately it was a cheap local tow.
    When I got home I pulled the lower dash cover and inspected the throttle linkage. I found the cable intact but the small rubber bushing in the pedal arm had disintegrated and fallen out. With no bushing holding it, the hook end of the throttle cable became detached from the pedal linkage. The rubber bushing (part# 35411152331) is a $2.50 item. It's easy to replace. This is a small and hidden wear part that I hadn't thought to check before (until it left me stranded). I figured I'd let everyone know. Maybe it saves someone else the hassle of a tow. This is 22+ year old rubber after all... it's gonna be hammered after many years of use. I bought one for my track car too.
    Below are photos of the old bushing that broke & fell out and the new one in place in the pedal linkage.
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    That’s on the accelerator pedal linkage? Wow, I haven’t heard about that issue. Thanks for pointing it out.
    Thanks for posting the part number, too!
    -rb
    1995 Avus Blue M3
    KC
    1995 M3 & 1998 M3 coupes
    Quote Originally Posted by RBNetEngr View Post
    -rb
    1995 Avus Blue M3
    This happened to me as well.
    Nov 2021
    Auburn, AL
    2015 Acura TLX
    This also happened to me! I wish I saw this post before it happened.
    Feb 2009
    Arizona
    1998 e36
    problem is that pedal stop is not adjusted properly so at every WOT bushing has to take all of the pressure of the throttle stop. It also seems that genuine bushing is harder rubber and aftermarket ones are softer rubber that does not last or falls out.
    PAC
    '95 E36 M3
    Does the bushing go in the top or bottom hole?
    Nov 2021
    Auburn, AL
    2015 Acura TLX
    Quote Originally Posted by Veleno View Post
    It goes in the bottom hole. The top hole is too small for it. It’s hard to tell but the bottom hole is larger.
    Feb 2009
    Mills River, NC
    Quote Originally Posted by hakentt View Post
    I can see this being a cause. Will check the linkage and cable system. I haven't messed with the pedal stop or throttle cable tension on this car but maybe a previous owner has.
    KC
    In my case the 23 yard old factory bushing crumbled away from the Texas heat. It had nothing to do with the pedal stop.
    Feb 2009
    Mills River, NC
    I checked the throttle pedal stop just now and that definitely wasn’t the problem. There’s a tiny amount of slack in the throttle cable when the pedal is fully on the stop. So like E85STI’s bushing mine just dry rotted and fell apart with age.
    PAC
    '95 E36 M3
    I'll check mine tomorrow after work!
    FCP has them for $2.69
    https://www.fcpeuro.com/Parts/?keywords=35411152331
    Oct 2020
    Manitoba, Canada
    e36
    What's the emergency fix if it falls apart in the middle of nowhere? Can you zip tie the metal end of the cable to the metal of the pedal and and prevent it popping out until you get a replacement?
    Feb 2009
    Mills River, NC
    Quote Originally Posted by importbanana View Post
    Yes. Unfortunately I was without zip ties when the bushing broke and a tow truck had already been called. I thought the throttle cable had snapped. While waiting I used the screwdriver in the factory tool set to remove the cover panel under the dash and look around. I found the failed bushing right as the truck pulled up. But you could certainly rig something to keep the cable end in place if it happens.
    PAC
    '95 E36 M3
    Did the pedal feel "loose" or without tension when it happened?
    Makes me think I should keep some zip ties in the car in case of any emergency! Good idea importbanana!
    Feb 2009
    Mills River, NC
    There's a return spring in the pedal linkage so the pedal still returns and feels roughly normal even when the cable isn't attached.
    PAC
    '95 E36 M3
    Quote Originally Posted by NoLastName View Post
    Thanks for clarifying.
    Feb 2002
    Honolulu, Hawaii
    1997 M3, 2dr/5spd*
    My throttle had been feeling a slight bit sloppy recently upon initial application when starting off and when reapplying the throttle after a shift, so I took a look at it today. There wasn't much left of the bushing, just a few pieces of sticky, crumbling rubber. The arm where the bushing fits is a bit different than the OP's, one hole instead of two, but installing the new one was a snap...the worst part was refitting the finicky under panel.
    I had ordered the bushing from FCP Euro back in February when I first came across this thread. When it arrived I placed it in a safe place so I could easily locate it when it was needed. At the beginning of this month I decided to swap out the bushing, but after looking high and low couldn't find the new one, so I ordered a replacement. This is the kind of stuff you deal with when you're 79 years old, just happy that I can still change oil and fix the easy to get to small stuff...
    Estoril/Modena '97 M3...sold for the second time.
    You only live once, and I'm running out of time...
    PAC
    '95 E36 M3
    It appears FCP has increased their price to $3.19
    Bimmerworld $2.69
    https://www.bimmerworld.com/ssearch....ry=35411152331
    ECS $2.24
    https://www.ecstuning.com/b-genuine-...g/35411152331/
    Checked mine today and there's nothing left. Time to order a bunch to have some spares on hand!
    Feb 2002
    Honolulu, Hawaii
    1997 M3, 2dr/5spd*
    Price may be up, but check the shipping cost...FCP usually beats the others.
    PAC
    '95 E36 M3
    Quote Originally Posted by Gene V View Post
    Yeah I checked that too. It was cheaper through ECS for me.
    Oct 2020
    Manitoba, Canada
    e36
    Today I replaced mine. Old one didn't look like it was about to fail but still good to replace it.
    Sep 2003
    Durham, NC
    95 M3
    If you have a local dealer it might be worth a check with their parts department. Last year when mine failed 35-41-1-152-331 was $2.27 + sales tax and I was able to pick it up next day.
    Jun 2012
    San Antonio, TX
    1995 BMW M3 Coupe
    So, this happened to me last week as I was leaving COTA after participating in a BMW M Track Days event. I didn’t have anything available to temporarily fix it, but I searched around and found a discarded heavy wire cable (Nite Ize rubber twist tie) and my son had it installed in a few minutes and we were on our way.
    I bought a new bushing from the local BMW dealer. They wanted to charge me over $6 for it, but when I showed them my BMWCCA membership card the price dropped to $2.24, including tax.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Jul 2011
    Bay Area
    E36 M3, W204 C63, etc et
    I might have to check mine out. I couldnt tell where it was from the pic but looked up Z3 pedal bushings on youtube and came across this in case anyone else is a more visual person
    https://youtu.be/m7_05tR8TYA?t=615
  1. Check your throttle cable!
    By nightkrawler in forum 1992 - 1999 M3 (E36)
    Last Post: 09-03-2010, 12:11 AM
  2. Replaced my Throttle Cable Bushings
    By Tomlite in forum 1995 - 2001 (E38)
    Last Post: 10-18-2009, 05:58 PM
  3. Billet Aluminum Throttle Cable Bushings
    By Tomlite in forum 1988 - 1994 (E32)
    Last Post: 10-11-2008, 12:03 AM
  4. Throttle Cable Bushings-special version M60/62 engine
    By shogun in forum 1995 - 2001 (E38)
    Last Post: 06-25-2008, 10:46 AM
  5. check those throttle cables!!!
    By ///M3 CRAZY in forum 1992 - 1999 M3 (E36)
    Last Post: 12-21-2003, 05:21 PM
