Results 1 to 7 of 7
Thread: G30 brake light reset
    Feb 2021
    North Carolina
    2013 M3, 2017 540i
    Frustrated. Just replaced front brakes on my 2017 540i but cant reset dash brake lights. Dealer wants $85 to do it and wont tell me how to do it manually. Any ideas? All i can find online is for previous generation F10. Thanks.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    There’s some missing details to say if this will work or not...but if you’ve seen any of the many videos on YouTube for any F chassis BMW...the procedure is basically the same except that in the G chassis BMWs...with your foot OFF the brake pedal...you have to press the START button THREE TIMES (instead of once like on the F chassis BMWs). And this should allow you to scroll through the CBS (condition based services) screens when you press the trip odometer reset button on the far left of the instrument cluster.
    But do read the info below to determine if you can use the instrument cluster reset procedure. If your brake pad sensors did not wear down...and/or you didn’t replace them...then the in car/cluster procedure won’t work.
    Feb 2021
    North Carolina
    2013 M3, 2017 540i
    Quote Originally Posted by WiseM View Post
    Thanks for trying. I did replace the wear sensor. But no matter what i try, the dash does not bring up the CBS options
    Feb 2021
    North Carolina
    2013 M3, 2017 540i
    I finally got it to reset with my scan tool. Had to have the engine running, then the cbs reset.
    (northeast) Indiana
    Great...thanks for posting back that you resolved the problem...and most of all...you posted a solution.
    Sep 2021
    McMurray,PA
    2019 BMW 530i 2018 BMW
    I am having the same problem what scan tool did you use to reset the service brakes light?
    (northeast) Indiana
    Are you attempting the instructions in post #2 with your door open? If yes, close the driver’s door, press the START button 3 times as outlined in the instructions…then press the trip odometer reset button until the CBS reset screens appear (or hold the BC button on the turn indicator stalk if you don’t have a trip odometer button).
    If you have the Bimmerlink app…and an OBD II dongle (or e-net able)…you can use that app to reset the CBS services, too.
    Instrument cluster CBS reset:
  1. G30 Brake light reset
    By WiseM in forum 2017+ (G30)
    Last Post: 02-25-2021, 01:48 PM
  2. E46 2000 Brake Light Reset
    By ox12345 in forum 1999 - 2006 (E46)
    Last Post: 12-13-2010, 01:29 PM
  3. Brake Light Reset
    By alisahellman in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-03-2009, 11:11 PM
  4. Brake Light Reset
    By alisahellman in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-01-2008, 11:57 PM
  5. 01 325 brake light reset
    By Btefer in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-16-2006, 08:33 PM
