Results 1 to 6 of 6
Thread: e36 Euro Lights - City Light and Self Leveling Operatoins
    Oct 2005
    Tracy, CA
    e46 325XI, e36 M3
    Getting a set of euro lights and I want to take advantage of both these features.
    For the city lights - how are they supposed to operate in europe from the factory. For example, does it come on when the car starts (DTR?), parking lights only, or when low beams are on? What would be the best way to wire them
    Self Leveling - is pretty self explanatory but does anyone have the P/N for the harness? Does the socket also have a cap part number to seal off if I choose to remove the motor?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    old thread from lighting forum moved to E36 forum.
    The Netherlands
    DE-spec E36 328i/M3 cab
    Some (Northern) countries excepted, no EU E36 has DLR's. So no lights come on with ignition on.
    Lightswitch pos 1: City lights
    Lighswitch pos 2: City lights + main beam.
    Front fogs are independent and can be use from lightswitch pos 1.
    There is also parking light function where the city lights on one side can be lit (ignition off, lightswitch off, stalk to indicator pos L/R)
    There is no self leveling on the E36. There are adjustment motors. Without motor you need to install a special part, as otherwise the inner frame will pivot freely. Just a cap will not suffice.
    IG:
    The Netherlands
    Wiring loom p/n: 61 12 9 410 627 (NLA)
    IG:
    Jul 2021
    Southern IN
    325i
    Just splice the city lights to the parking lights.... could wire in a relay to ign so they only function w ign on....
    I bought my used bmw 10 years ago and I still have it....
    Proof that you can't fix stupid....
    Jul 2012
    Atlanta, Georgia
    ∞FX37,M3a/4,94 332
    For the city lights, get a Euro fog light switch and use that with a light duty relay;
    https://www.amazon.com/Directed-Elec...353657&sr=8-50
    For the headlight leveling, use the fixed ball-end holder, not worth the time, energy, effort for the adjustable version.
    [IMG][/IMG]
  1. E36 FS: E36 Euro/DEPO Tail Lights for coupe/convertible
    By estorealjon in forum Exterior Lighting & Body Parts
    Last Post: 11-25-2022, 05:01 PM
  2. E36 E36 Euro Rear Tail Lights Red/Clear OEM Sedan 92-99
    By ///M297 in forum Exterior Lighting & Body Parts
    Last Post: 03-09-2014, 01:30 AM
  3. E34 guys with euro ellipsoids, city light?
    By phatfarm in forum 1988 - 1996 (E34)
    Last Post: 11-20-2007, 07:16 PM
  4. Replies: 11
    Last Post: 12-17-2005, 12:07 AM
  5. Euro Elipsoids: City light connection.
    By craigrolf in forum 1983 - 1991 (E30)
    Last Post: 07-27-2005, 07:28 PM
