I have been tinkering with it for a while now. Opens fine from the inside, locks as well. On outside, the handle pulls put fully, but will not open the door. I took the inside panel off and can see the outer handle engaging on the mechanism that goes down to the actuator. I suspect the issue is in the actuator itself. If I were to fully remove it, will I be able to address the issue or need a new/used other actuator?
I also understand that on a 2000 323 ci, there were 2 different actuators used (depending on DOM)
The latch is bad and the actuator could come with it go to reloem.com enter the vin go to section 41
Try reloem only it will come up
It’s actually www.realoem.com.
If you can’t attempt different ways to find reloem then your not looking hard enough
