Results 1 to 9 of 9
Thread: No Crank after Mechatronics Seal Replacement - 2004 530i
    Oct 2008
    Denver
    '91 M5
    Good afternoon,
    I’ve done a good but it searching and could use some input from E60 gurus.
    I replaced the transmission filter/seals/fluid on my 2004 530i. The first time I put it back together I did hit have the sleeve seal all of the way in, so I tried to start the car but the mechatronics was disconnected from the rest of the car. Tons of lights on the dash and warnings, and would not crank.
    I dropped the filter again, dropped the mechatronics unit, checked the pins on it to make sure I didn’t damage anything, and reinstalled it all and am confident that the harness and mechatronics unit have a good connection now. I ensured the position of the gear selector cables before putting the pan back on - it is in the notch where it is supposed to be. I have filled it up with fluid and want to turn it on to complete the full process and it won’t even try to crank. No clicking from the starter like it wants to - just nothing happens. I’ve hooked up another car to make sure it isn’t a coincidental battery problem and nothing changed.
    I have tried the pedal down for 30 seconds which has worked before but isn’t clearing the codes now. I removed the battery and shorted the leads together for 15 mins and that didn’t clear anything.
    I don’t have access to INPA or anything more than a cheap harbor freight code reader.
    If I had the harness in wrong the first time, is it possible that the car won’t let me try and start it until I get in there and clear the codes, or would it fix itself once it was plugged in properly (and I’ve just damaged something or have screwed it up again)?
    Thanks in advance, wish me luck.
    Current Fleet:
    E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
    Past:
    E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
    E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
    E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
    E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
    E39 1998 528i 5-Speed Black on Black - Sold locally.
    E34​ 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Maybe you are not in neutral. I did this years ago on my 535xi and did not get the shifter arm in the correct slot or alignment. I forget the exact details, though. Had to drop the pan again.
    Oct 2008
    Denver
    '91 M5
    I knew that would be a potential cause so I made extra sure to verify that the slider and notch were aligned before I put the pan on the 2nd time.
    Current Fleet:
    Past:
    Mar 2016
    Hertfordshire
    e61 touring RIP e39 wagn
    TBH , I wouldn’t have bothered putting all the pan and oil back in until the starter can be heard , that’s just me .
    Have you checked all the fuses in the car as a precaution ect , maybe the plug crossed pins and shorted un-intentionally.
    I think something like this error will need inpa or ista to diagnose the issue if all fuses are ok .
    Jun 2005
    New England
    I think I also had trouble seating the electronics plug on the outside. It was a tight fit on my Xi car.
    Oct 2008
    Denver
    '91 M5
    Quote Originally Posted by Barnesautos View Post
    I took it all apart again and was able to get the sleeve in even tighter, prying with a screwdriver carefully. Still nothing when I turn the key. I had doubts with the battery so I replaced. I have been trying to start the car now with the pan off - will the car crank over without the pan/fluid? I checked around for some sort of sensor that might keep it from cranking but did not see anything.
    I will check fuses.
    Current Fleet:
    Past:
    Jun 2005
    New England
    Can you start in neutral? Did you try disconnecting the battery, waiting, and then reconnecting it? My sense, from having done decades of DIY work, is that the problem is something you did rather than a coincidence. I have been there many times myself over the years. The most likely thing to me is that the car does not think it is in park or neutral. The question is why. When I had an issue after doing mine, I posted over in 5series dot net and someone there helped me. At least a few years ago, that forum was much more active for E60/61 than here. Post back what you learn, if anything.
    Oct 2008
    Denver
    '91 M5
    I agree, very likely I broke something or did not put it back properly. I let the car sit for a few days with the battery disconnected and the error messages did not go away.
    I ordered an Ancel BM700 code reader and tried to clear the EGS fault codes yesterday. It said that the function was not supported on that model, which I think was its way of saying that it was unable to communicate with the EGS. It also said that it was not able to read the battery when I tried to register a new one, so I might have to make sure the software is up to date and contact Ancel to know for sure.
    I am very confident that the physical connection is good now. I have dropped and replaced the mechatronics a few times, and have the sleeve very well seated/flush with the transmission housing, and the harness slips right in when I connect it.
    I am thinking I damaged the mechatronics when removing it, and it will need to be replaced. I just want to find a way that I can verify that so I am not just throwing parts at it.
    Current Fleet:
    Past:
    DE, USA
    '15 435i,'10 535i,'08 X5
    Check for bent pin(s) at EGS connector.
    Jun 2023
    Bay Area CA
    06 550i
    So what was the outcome of everything?
  1. Replies: 0
    Last Post: 12-30-2013, 08:42 PM
  2. Crank case, main seal replacement help
    By ihavea325is in forum 1983 - 1991 (E30)
    Last Post: 06-19-2013, 03:56 PM
  3. P0340 after vanos seals replaced
    By adaptableyeti in forum 1996 - 2003 (E39)
    Last Post: 10-02-2012, 07:11 PM
  4. Rattle after Diff Seal Replaced
    By brandonbester in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-30-2011, 10:59 AM
  5. M3 whining noise after differential seal replaced PLEASE HELP!
    By tnsman83 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-18-2008, 07:00 PM
