Results 1 to 6 of 6
Thread: reusing arp head hardware
    Jan 2019
    houston
    2017 F150, 97 M3
    Is there any advantage to purchasing new arp head hardware vs reusing a used set? I don't want to cut corners but I also don't want to throw away money for nothing.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I had one set of studs that I reused 4 times over several years. Motor was turbo. The studs were never a problem. You can measure for stretch if you yo be certain. I never measured and those studs were torqued to the original ARP spec with the two 90s that tested at about 120 lbs. ARP later changed to straight 85, and I think may now be 75.
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    What boost ya running? High boost is where this can become an issue. 20psi, is probably no problem. If you are up around 35+psi, then I would not test it. The good thing is that they don't fail catastrophically and will just blow the HG which you should be able to catch before it becomes an issue.
    Bellingham, WA
    1998 M3, 2001 530i
    clean the used ones off really well and check for white wear marks on the threads and any necking down or other deformation. Undamaged used and properly relubricated studs will work the same as new ones.
    Sent from my LM-V350 using Tapatalk
    Jan 2019
    houston
    2017 F150, 97 M3
    thanks these were off a turbo motor running 18 psi
    Jun 2012
    Socal
    turbo e36
    Ive reused my arp studs on 3 motors? No issue with gasket sealing yet, have thrown rods, melted pistons, fun stuff.
  1. Can you reuse ARP Head Studs?
    By StuddMan in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-26-2006, 08:12 AM
  2. WTB S52 ARP head studs
    By jmargo in forum Race Cars & Track Parts
    Last Post: 10-31-2005, 02:39 PM
  3. FS: ARP Head Stud Kit - s50/52 & m50/52
    By mrdoenutz in forum BMW Parts For Sale
    Last Post: 03-05-2005, 01:39 AM
  4. RACEWARE of ARP head studs........which to go with.
    By DukeM535i/Turbo in forum Forced Induction
    Last Post: 10-27-2004, 05:21 PM
  5. ARP Head Stud Washers
    By subpilot in forum Forced Induction
    Last Post: 08-27-2004, 03:08 AM
