Results 1 to 5 of 5
Thread: FS: StopTech black ST40 332mm Front BBK (slotted rotors)
    Northwest NV
    Audi B8.5 S4
    SOLD!!!!!!
    StopTech E36 M3 + Z3M Coupe/Roadster front BBK. This is the ST40 (4-piston) setup with 332mm rotors. Calipers are gloss black. Braking with these will peel your contacts from your eyes. Don't let people tempt you into 355mm setups - 332 will handle everything you throw at them.
    These can fit under factory Style 40 (Roadstar) wheels, but require ~18mm spacer for lateral clearance, and you MUST NOT have wheel weights within the narrowest part of the wheels' barrels (radial clearance).
    Kit is lightly used and nearly-new. Only about 1000 - 2000 miles (zero track time) on them. Includes everything from the factory kit:
    Two black ST40 calipers (including the caliper bridges and four bridge retaining bolts with washers).
    Two slotted two piece rotors/hats (332mm diameter).
    Two mounting adapter brackets (that connect to the the factory hub/spindle assembly where the original caliper carriers mount) and four jet nuts + washers.
    One complete set of ST front brake lines (banjo fittings) with two banjo bolts and six crush washers (two per banjo fitting, one at hard/flexible line connection)- washers are used, so you'll have to source new ones.
    One complete set (four pads) of StopTech Sport brake pads (used).
    Recently did a deep clean, polish, and ceramic coat on the calipers and rotor hats (not quite back to 'as-new,' but close). There is still some residual rust on the brake rotors. This is normal oxidation of the ferrous material in the rotors and pads.
    In addition to the lightly-used StopTech sport brake pads, I'm including the currently-bedded-in pads, Porterfield R4-S, which are sooooo much better than the ST sport compound.
    $1700 + shipping.
    Initial Install, April 2019:
    Initial Install by BMWBergy, on Flickr
    IMG_8425 by BMWBergy, on Flickr
    Cleaned and Ceramic Coated, December 2020:
    IMG_9136 by BMWBergy, on Flickr
    IMG_9097 2 by BMWBergy, on Flickr
    IMG_9971 by BMWBergy, on Flickr
    Dec 2008
    philly
    tundra
    Will these fit my 96 bmw e36 m3, thanks
    Feb 2016
    Rogers AR
    1995 BMW M3
    Quote Originally Posted by yzwilly View Post
    yes they will
    Feb 2021
    Sping, TX
    1997 BMW M3 Sedan
    PM Sent
    Northwest NV
    Audi B8.5 S4
  1. FS: StopTech black ST40 332mm Front BBK (slotted rotors)
    By BMWBergy in forum Z3,Z4,Z8 Classifieds
    Last Post: 01-13-2021, 04:24 PM
  2. E36 FS: Brembo/Mov'It 332mm Front BBK
    By busterhax in forum Race Cars & Track Parts
    Last Post: 04-09-2014, 11:15 AM
  3. E36 E36 FS: Brembo/Mov'It 332mm Front BBK
    By busterhax in forum Brake Kits, Rotors & Pads
    Last Post: 01-30-2013, 01:04 AM
  4. Replies: 6
    Last Post: 12-14-2008, 12:05 AM
  5. Replies: 13
    Last Post: 08-04-2007, 02:19 AM
