SOLD!!!!!!
StopTech E36 M3 rear ST-40 BBK. This is the 4-piston setup, with black calipers slotted 332mm x 32mm rotors. Braking with these will peel your contacts from your eyes. Don't let people tempt you into 355mm setups - 332 will handle everything you throw at them.
Kit is lightly used and nearly-new. Only about 700 - 1000 miles (zero track time) on them. Includes everything from the factory kit:
Two black ST40 calipers (including the caliper bridges and four bridge retaining bolts with washers).
Two slotted two piece rotors/hats (332mm diameter).
Two mounting adapter brackets (that connect to the the factory hub/suspension arm assembly where the original caliper carriers mount) and four jet nuts + washers.
One complete set of ST rear brake lines (banjo fittings) with two banjo bolts and six crush washers (two per banjo fitting, one at hard/flexible line connection)- lines and all line hardware are completely unused.
One complete set (four pads) of StopTech Sport brake pads (used).
Recently did a deep clean, polish, and ceramic coat on the calipers and rotor hats (not quite back to 'as-new,' but close). There is still some residual rust on the brake rotors. This is normal oxidation of the ferrous material in the rotors and pads.
In addition to the lightly-used StopTech sport brake pads, I'm including a brand new set of Porterfield R4-S, which are sooooo much better than the ST sport compound.
$1700 + shipping.
I also have a matching front BBK (same specs), which I'll post up for sale when I'm able to upload those pictures.
IMG_9809 by BMWBergy, on Flickr
IMG_9509 by BMWBergy, on Flickr
IMG_9862 by BMWBergy, on Flickr
IMG_9807 by BMWBergy, on Flickr
IMG_9806 by BMWBergy, on Flickr
DIY/Project Links:_TC Kline D/A & Suspension Refresh_|_Oil/Engine Cooling Options / Install_|_
Dinan/Fikse FM-5 Build_|_Stereo Install_|_HID Retrofit_|_
PM Sent
