I took a balancer over to the drill press and used it as a pattern to drill some scrap plate, then welded it to some square stock.
Hangs on my toolbox.
Use it all the time with an enhanced breaker bar. No impact required. 20210205_100235.jpg20210205_100349.jpg
Not enough room for past/present garage
the rope will stop rotation, but that crank bolt torque goes way above the normal torque a single piston/rod normally sees. Likely would work, but some element of risk involved. I bet it would hold, but eh not worth it IMO.
Use a holder at the crank pulley.
this is one of the options that I was looking at.
I have seen this before. Definitely a contender. I have to see what scrap metal I have lying around.
I like the idea but with the amount of torque this bolt requires I don't think I will try it this time. I will definitely keep it in mind in the future
I only use the rope trick to hold up valves during on car spring removal.
Well it’s running. I did a quick start up to check for major issues and leaks. I still have to install the new Jesus bolt. I need to make the tool.
I could hear a ticking noise from the passenger side. Hopefully it goes away. It was not super loud but there.
https://youtu.be/nsjtUx7hYzc
That sounds pretty good for the first start. Usually they sound like a can of marbles on the first start.
Nice work on the rebuild! You really went through it pretty quickly even with all the extra parts. Mine was definitely ticking on start up. After it warmed up I took it for a casual mile loop and when I came back it was purring.
For the life of me I do not understand why you guys love this V-8 so much or why you wouldn't just yank that pig out for this kind of service.
My back is killing me just looking at this picture.
I'm used to working in the engine bay. I was also doing this in the driveway because my other toys don't get left outside and I only have a two car garage.. I really had no idea it was going to be this much work and only bought this because I have always liked this body and I don't want to pay M5 prices.
Well the chain guides are done. This car has some nice torque! I did snap a 1/2” breaker bar. I hit harbor freight for a 3/4” breaker bar and a 3/4” socket set. Thank you to everyone that chimed in. Now I have to clean this car and fix some things.
Yeah size matters. 3/4 breaker makes life much better.
Thanks. I have put 30 miles on it so far and no codes. I also put it through it’s RPM range and it’s runs great. The slight ticking sound went away. It drives smooth at 80 no issues that I can tell so far. I now have a lot of detailing to do. Also I have to fix a twisting seat on passenger side which I have seen the videos. The driver side seems like the twist was fixed but leans so I need to get back in and fix that. Also the windshield wiper is bowing up.
Yes it does!
getting the last 30 degrees was a little scary. I used the 1/2 for the vanos with no problem but now I have a 3/4” setup.
So far 30 miles and no codes. We will see as time goes on. I need to go get it smogged to finish the registration. It’s super smooth and quiet! Do these cars have positraction? It seems to spin one wheel.
No posi (LSD) on any E39 except the M5
I want to put a LSD in mine eventually but its a little cost prohibitive at the moment.
I’m back!! So after a couple hundred miles the check engine light came on with p0021. Atleast I got the car smogged before it came on.
I also just put all new power stop z26 rotor and pads on with ECS braided lines since the engine bay one was leaking.
So far the car has been a blast to drive. It is very touchy of the line which is super fun.
