Hello - The car: 2014 BMW 335I Nov 2013 Build Date
I have replaced the sensors twice, once with after market and another with Discount Tire set. Neither resolved the TPMS malfunction error.
So, I don't think it is the sensors and moved up the chain. I replaced the current antenna (see picture 1) with a used OEM unit came from the same build date.
When I started the car, it was showing 3 wheels in green and one in orange (low pressure) warning even though all tires are having correct pressure. After resetting, the TPMS Malfunction error returned despite many drives and re-resets.
I replaced that antenna with another used unit and now, got a warning screen showing the 4 tires are low pressure when the actual pressure are fine (see picture 2).
What do you recommend to do next as I am afraid to reset TPMS and get the malfunction error again?
Any input is greatly appreciated!
The pictures are not displaying
If possible, I want to see the error codes that came from the original module (so called RDC), and then the replacement one. This would require a tool capable of reading BMW codes.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
This is before I reset TPMS. After resetting, I get the standard TPMS Malfunction message.
Those are not error reads from a diagnostic read from the diagnostic port....
Either way, what happens if you inflate all tires to above 35psi? Using a confirmed good gauge?
-Abel
-Abel
Ended up replacing both RCD and sensors to get issue resolved
