Hi,
Need to figure out what exactly i need since there are a few parts that could be culprit. When i release the handbrake, it pops back up, however, doesn't pop all the way back as my handbrake light stays on. I have to pull it up a few times (combined with pulling on the handbrake release handle) to get it stuck up just right. I first thought that maybe its the shock, but then i figured it could also be some springs that are in the system. I used the diagram below for reference. Also, FCP euro/amazon don't have those springs (if they are a culprit), any other place to find them?
https://www.realoem.com/bmw/enUS/sho...diagId=35_0167
It could also be the cables. If they get rusty in the housings, all sorts of strange things happen
subscribed...I have the same problem
#8 https://www.autohausaz.com/pn/SS-35511165407
Sent from my SM-G965U using Tapatalk
Which US e38 came with a handbrake?
EDIT: noticed you say s62, so this is a swap? Going to be a plethora of possibilities if so.
Handbrake / foot pedal powered, but still a handbrake.
Disconnect the cable at either part 13/19, or at 21 - where the cable attaches to the arm. See if there is any binding.
This is quite a normal problem - the damper on the E-Brake mechanism needs to be replaced: https://www.realoem.com/bmw/enUS/sho...67#35511165407
My BMW Repair YouTube Channel
Just lift up on the pedal with your foot when you pull the release cable. Problem solved!
E38 1998 740iL DM24826 - Arctic Silver Metallic / Gray - 185k
Retrofits/Modifications: Bi-xenon lights with angel eyes and city lights, 750iL grab handles and rear interior lights, facelift kidneys, Euro front plate, 2001 tail lights, auto wipers, auto headlights, interior and exterior illuminated door handles, Steptronic, "Max AC" IHKA panel, comfort exit/entry, LED high beams, rear seat foot rests, footwell lighting, Avin Avant 4, Monsoon rear deck subs and door woofers, wireless charging, hydraulic trunk (coming soon)
E38 2001 750iL Sport DD74513 - Titan Silver / Black - 175k
BMW CCA # 573127
As others have said, just hold the handle out and pull up on it a bit with your foot. It is definitely the part everyone has been referencing and there honesty isn't much of a use replacing it unless it breaks in half or something.
The shock is a good place to start, but it could also be the adjustment of the cable under the car.
Trevor
01 749i sporty, build 12/00 "Sports Barge",S62
92 VW Corrado VR6,AAA
81 Delorean,B28F
81 VW Rabbit Pickup 1.8T,AWW
03 VW Passat wagon 4.0 W8 6spd
