Results 1 to 5 of 5
Thread: M3 Convertible stock ride height
    Jul 2004
    sf bay area
    99M3 Convertible
    Can someone with a stock M3 take some measurements of their ride hide from the center of the wheel arch to the ground? Specifically the rear. My rear passenger side is 0.5" lower than the driver side and I'm not sure why. The only thing i can think of is the battery is on that side but I don't think it would cause it to lower that much. I know bentley's says 0.5" is about the max deviation between sides but still seems too much. I'm mainly concerned because I'm rubbing on that side with my wider aftermarket wheels.
    thanks!
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    The rear is supposed to be lower than the front. The spec calls for left and right to be within 10 mm (3/8 inch) of each other. The M3 spec is 21.25 inches for the rear and 22.05 for the front.
    The measurement is taken from the lowest point on the rim to the highest point on the fender opening. DO NOT measure from the ground. The measurement is also for a 17" wheel.
    Jul 2004
    sf bay area
    99M3 Convertible
    thanks, I have the bentley specs. Still hoping someone can measure theirs
    Miamisburg, Ohio
    1997 328iC, 2003 Z4
    Try measuring it with someone sitting in the drivers seat. Bet it comes out a lot closer. I remember when aligning them, BMW instructs you to put a specific amount of weight in the seat to simulate a driver being there.
    Jul 2010
    Murrieta, CA
    If the passenger side is more than 10 mm (3/8 inch) than the driver side, you have something broken, probably a spring. If the springs are factory parts, then you easily can have one that is fatigued. Ride height is a function of the springs, not the shocks.
  1. Silver E46/M3 front/stock ride height/no skirts
    By mLuMaN83 in forum BMW Rides & Events
    Last Post: 11-05-2011, 07:16 PM
  2. Stock ride height springs for e46 M3
    By SKYWLKR in forum Suspension Tech and Handling sponsored by eBMWParts.com
    Last Post: 09-01-2009, 06:04 PM
  3. Widest Front Tire - 99 E36 M3, stock Ride Height
    By Dinanify in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-16-2004, 07:45 PM
  4. Stock Ride Height for '98 M3/2
    By Gatorbait in forum 1992 - 1999 M3 (E36)
    Last Post: 03-17-2002, 05:43 PM
  5. susp newbie - keeping stock ride height w/ new shocks
    By sammy328 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-12-2001, 01:59 PM
