Results 1 to 9 of 9
Thread: What are these cables for?
    Oct 2017
    Croatia
    1991 BMW 525i E34
    So yesterday i swapped my front lights and found cables dangling below it what are these for?
    https://imgur.com/bdj2WZ9
    Also found a couple below my central dash and was wondering what are those for too.
    https://imgur.com/9gXWL9k
    Sep 2017
    Vienna, VA
    1995 525i E34 6-speed
    The connector in the engine bay has got me puzzled, but the ones in the center console are all Auto trans connectors.
    Mar 2010
    Marin, CA
    1989 535i Manual
    Pretty sure the round one goes to the front bumper wiring harness (fog lights, headlight washers, temp sensor, side marker lights etc). Do you have any of these options on your car, and if so do they work with that cable unplugged?
    "Big Red" 9/88 Build 535i/5: E.A.T. Chip, 24lb Bosch Design III, 3.46 LSD, 4x Clear corners, DINAN-style 750i muffler, Racing King Subframe Inserts, Koni/Vogtland suspension, E34 M5 swaybars, Brembo/Porterfield brakes, Turbodiesel grills, 16" Style 8 rims, Euro front plate, M5 rear filler plate.
    Save
    Save
    Oct 2017
    Croatia
    1991 BMW 525i E34
    I got fog lights but they work fine and also the temp sensor works fine too. Weird.
    Sep 2017
    Vienna, VA
    Quote Originally Posted by sbeckman7 View Post
    There was no such connector. Those are all pry of the main body loom.
    Mar 2010
    Marin, CA
    1989 535i Manual
    Hmm. All I can tell you is that my car has that connector hooked up and it terminates at the front bumper wiring. It's not headlights, but I thought it was side markers, fog lights, etc. When I pulled the bumper off it was the only wiring connecting the bumper to the rest of the car, hence why I figured it was for the front bumper items
    Save
    Save
    Sep 2017
    Vienna, VA
    Hmmm. I am open to the possibility that it is an early e34 thing. But would need confirmation.
    Jul 2011
    Ann Arbor, Michigan
    1995 BMW 525i 5 speed
    Totally off the wall guess here but i think it might be for a motorized headlight aiming adjustment? Total guess on my part. Cheers, George
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    electric headlight aim motor socket plug has only 3 pins.
    how does the plug for cruise control look like?
    Maybe you go thru all the pics at the end of the ETM under component location views https://shark.armchair.mb.ca/~dave/BMW/e34/
  1. Location of speedometer cable in 95 M3?
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 02-26-2002, 11:36 AM
  2. Running cables, how to access??
    By BAADDOG in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-05-2001, 10:09 AM
  3. RCA Cable Questions
    By KmanM3 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-09-2001, 09:38 PM
  4. Is there a way to tighten the parking brake cable?
    By Stylin in forum 1991 - 1999 (E36)
    Last Post: 08-15-2001, 01:13 AM
  5. M3 Manual Seat Lever and Cable
    By Hank in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-14-2001, 10:12 AM
