Results 1 to 6 of 6
Thread: Old link not active
    Jul 2011
    Ann Arbor, Michigan
    1995 BMW 525i 5 speed
    Old link not active
    http://home.comcast.net/~winstonfong...illremoval.htm
    Greetings,
    anyone have the above link that works? I get nothing when I click on it.
    It’s for the center grille removal.
    cheers, George
    Jan 2021
    Az
    E36
    Thread some 100# chain thru the louvers and use a windlass to add tension. Place the car in reverse and rev to 9000rpm then pop into 3rd. This will take care of it.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    see my last post that link works https://www.bimmerforums.com/forum/s...-grill-removal
    winston Fong's site is dead since years and nothing available with wayback machine
    Jul 2011
    Ann Arbor, Michigan
    Thank you Shogun!!
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    I found it in the wayback machine but it was a bit tricky.
    Here's the page for the original URL: https://web.archive.org/web/2017*/ht...illremoval.htm
    However if you follow the later snapshots, you basically get redirect and not found errors.
    Instead, I went to the earliest snap and got: https://web.archive.org/web/20030713...illremoval.htm
    "Howdy, Folks!"
    Jul 2011
    Ann Arbor, Michigan
    Richardodn thank you so much for your efforts! I appreciate it! Cheers, George
  1. Vendors link not working
    By ElSupremo in forum Forum Software Questions & Suggestions
    Last Post: 01-03-2005, 02:09 PM
  2. New (old) Amplifier not working 93 325i
    By amucci in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-25-2004, 10:29 PM
  3. cool link *Caution - Link Not Work Safe*
    By punknamedjimmy in forum Off-Topic
    Last Post: 11-24-2002, 07:01 PM
  4. OBD II plug not active? My smog check guy...
    By sedate in forum 1992 - 1999 M3 (E36)
    Last Post: 03-19-2002, 02:44 PM
