Results 1 to 2 of 2
Thread: Po171 code
    Jan 2021
    Lexington Ky
    2009 BMW 328i xdrive
    Po171 code
    Have an 09 328i xdrive that recently wouldnt start. Had towed to dealer and they replaced battery and cleared codes. Started and ran fine for a few days then same issue. Only thing showed up was 4x4 faliure. I reset codes and car started. Happened again a few days later and same thing. Now it runs fine and starts fine but the service engine light came on and it is throwing a lean code. My valve cover is leaking oil and was wondering would this cause the issue of it not starting. It would crank until battery went dead and wouldn't even act as if was about to fire. I dont want to spend the money replacing gasket and possible valve cover if it happens to be the filter on it and then have it not start again. Any help in this? The dealer will not even speak to me about anything without paying to have them do work first then tell me what they did.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    No, only a massive vacuum leak would prevent the engine from starting.
  1. PO174 / PO171 codes and other symptoms..
    By GLOCKMOM in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-11-2010, 09:12 AM
  2. informatio reguarding codes po171 po174 po455
    By 7partsonly in forum 1999 - 2006 (E46)
    Last Post: 09-05-2010, 07:51 PM
  3. E46 codes po171 & 174
    By mcarita in forum 1999 - 2006 (E46)
    Last Post: 07-06-2010, 09:27 PM
  4. Codes po174,po340,po171
    By zeplover72 in forum 1995 - 2001 (E38)
    Last Post: 11-03-2009, 02:11 AM
  5. Service Code PO171 Question?
    By monsstr in forum 1996 - 2003 (E39)
    Last Post: 04-05-2009, 03:50 PM
