Results 1 to 8 of 8
Thread: BMW 32i 2007 Fault Code Meaning
    Dec 2020
    Australia
    BMW 320i 2007
    Lightbulb BMW 32i 2007 Fault Code Meaning
    Hi,
    Car: BMW 320i 2007 (140,000km)
    My car "check engine " indicator was ON when I was driving over 100kmh , around 4800rpm.
    Then OBD scanning was done and obtained following faults,
    2CA2 O2 sensor heater circuit (bank1 , sensor1) : Fault during overrun
    2CA3 O2 sensor heater circuit (bank2 , sensor1) : Fault during overrun
    Still I didn't reset check engine indicator. Can anyone explain what's wrong with my car and will it be ok after reset?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Sure you could clear the codes to see if they come back, however I think they will. Normally when you get both heater faults at the same time, that would point towards a fuse or relay so be sure to check fuse #78 if your was built after 02/2007. If it was built before that which I am assuming not as you have 2 pre-cat oxygen sensor codes, but for somebody else who may come across this thread it will be fuse #5.
    And for the very low possibility that the fuse is good, and the codes do come back, I would replace both oxygen sensors.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Dec 2020
    Australia
    BMW 320i 2007
    Thanks for your response.
    First I'll reset and see and then will check for fuse.
    Dec 2020
    Australia
    BMW 320i 2007
    Today I reset and run about 40km.... still no indicator.... Will it be ok ?
    dworthy's Avatar
    Nov 2010
    Sometimes things just trip for no reason. I get odd fault codes that have been inside some of the DME's when I do a full scan. All it means is one time that particular sensor didn't pass the BIT (Built in Test) but it still works properly.
    Give it some time, besides BMW recommends that you replace your oxygen sensors every 160k km or so depending on the model anyway.
    Darin
    Current:
    Past:
    M-Flight Member
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Weebly,
    What gear were you in and for how long were you driving?
    Jan 2016
    Ca
    2001 525it
    Heater circuit is part of the oxygen sensor, to get the engine burning as clean as possible as soon as possible the oxygen sensor has a built in heater so if the fault returns, then most likely the oxygen sensor needs to be replaced
    Dec 2020
    Australia
    BMW 320i 2007
    Quote Originally Posted by marvinstockman View Post
    Weebly,
    I think it was 3rd gear or 4th , driven about 10kM
    I got check engine again ....!!!! driven about 100km after reset.
    This time no chance I guess....
  1. 97 BMW 540i OBD fault codes
    By atp160 in forum 1996 - 2003 (E39)
    Last Post: 07-01-2008, 06:50 AM
  2. Replies: 7
    Last Post: 09-15-2007, 01:02 PM
  3. What does this fault code mean??
    By M3Cosmos in forum 1992 - 1999 M3 (E36)
    Last Post: 02-02-2005, 11:20 AM
  4. who knows what this fault code means?
    By pikachu in forum 1991 - 1999 (E36)
    Last Post: 02-15-2003, 03:53 PM
  5. Anyone know what this fault code means?
    By DakarDave in forum Forced Induction
    Last Post: 02-06-2003, 06:49 PM
