Results 1 to 3 of 3
Thread: Transmission slipping
    Feb 2019
    Minneapolis MN
    2005 BMW X3 3.0i
    2005 E83 3.0 149xxx I've noticed occasional transmission slipping for a month or so that has gotten worse in the last few days. Usually at highway speeds and sometimes while accelerating. Is there anything I can do or do I just wait for the inevitable? I know there's a lot of debate on changing fluid and filter.
    Mar 2019
    ATLANTA GA
    456 X3s
    Ive never used them but there are transmission fluid additives...
    Have you considered simply changing the fluid itself?
    Sent from my SM-J727T using Tapatalk
    May 2012
    FL
    E83, E21
    Change the fluid/filter, and change the fluid again after a few hundred miles, and again a third time. Each drain only removes about half the fluid.
    On the final drain/fill, pour in a bottle of Lubegard Red; it'll restore the friction between the worn clutch packs but not harm them or the solenoids. I use it on every automatic transmission I service and have had nothing but great results. I successfully rehabbed the trans in my 150k mile F150 that never had its fluid changed using the above process.
    I forget what the drain pan looks like on the 5 speed, but on the 6 speed BMW used a small (8mm) recessed Allen-style drain plug; if yours is the same, toss it and pick up a proper GM drain plug (14mm hex) to make your drain/fills easier. You may have to cut the un-threaded end off for filter clearance.
    E21 build
    BMW CCA 584213
    I buy socks from Amazon.
  1. Auto Transmission slips when cold
    By jftl1b in forum 1999 - 2006 (E46)
    Last Post: 11-10-2006, 10:28 PM
  2. transmission slip/hesitation
    By DP57 in forum 1999 - 2006 (E46)
    Last Post: 07-07-2006, 08:18 PM
  3. Automatic Transmission slipping
    By BMWQUEST in forum 1991 - 1999 (E36)
    Last Post: 07-03-2006, 03:47 PM
  4. Transmission Slipping? O2 Sensor funk?
    By FirstBmw325is in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-16-2005, 10:59 AM
  5. Just bought a 1995 325is and transmissions slipping when
    By fishkillnick325 in forum 1991 - 1999 (E36)
    Last Post: 09-30-2004, 12:33 PM
