HIGHLIGHTS
• FULL T6061 ALUMINUM CONSTRUCTION
• SECURED THROTTLE BODY CONNECTION
• DIRECT FIT
PROFILE
Complete your S55 upgraded charge piping with the ARM S55 J Pipe! This J Pipe is the final piece of piping on the S55 before the charge air enters the intake manifold. BMW constructed the OEM J Pipe of plastic which is prone to cracking an detaching from the throttle body under boost.
The ARM S55 J Pipe is constructed of T6061 aluminum for a durable replacement that will hold up to even the most demanding builds.
The ARM S55 J Pipe is designed to lock onto the stock throttle body using a CNC machined connector. This connector incorporates a locking C-clip design which replaces BMW's one-time use plastic strip to create a secure connection to the throttle body.
Included with the ARM S55 J Pipe is a pre-plugged 1/8 NPT fitting which allows for post-intercooler methanol or nitrous injection. This is the preferred location of injection for many S55 tuners.
For reinstalling your S55 vacuum line, the ARM J Pipe has a precisely machined vacuum line connection port to prevent any leaks, a common issue on many other S55 J Pipes.
IN THE BOX
• ARM S55 J Pipe
• Intercooler To J Pipe Silicone Hose
• Throttle Body Retaining C-Clip
• Replacement O-ring
• Clamps
FITMENT GUIDE
- BMW F80 M3
- BMW F82 M4
- BMW F83 M4
- BMW F87 M2C
ARM MOTORSPORTS LIFETIME WARRANTY
Every ARM Motorsports product is backed by a lifetime warranty which is automatically issued at the time of purchase. Your warranty protects you against any defects in craftsmanship or fitment. The warranty entitles you to a replacement unit.
